Here is how to fix error 502.
Rick
» Reposition the Encoder Strip on the
A940 All-In-One Printer
To reposition the encoder strip, perform the following steps:
Remove the power cord from the unit.
Lift the lid of the unit, just below the scanner portion of the All-In-One,
to expose the inside of the unit where the printer cartridges are located.
Gently slide the ink cartridge carrier to the middle of the
printer.
Figure 1:
Out-of-position encoder strip
Gently move the top part of the printer belt to the right.
Using your index finger, gently push encoder strip down and then back up to
get it back into the slot located on the back of the ink cartridge
carrier.
Note:
There is a small slot that the encoder strip fits into, which is located on
the back of the ink cartridge carrier.
While working with the encoder
strip,
check it for dust or any unclean spots. If any detected,
try to clean the strip by wiping it gently with clean cloth.
Gently press the strip first to the rear and then forward to ensure that it
is seated correctly.
Manually move the ink cartridge carrier to the left, then to the right to
check the positioning of the encoder strip.
Figure 2:
Correctly seated encoder strip
Note:
If the encoder strip moves at all, it has NOT been repositioned
correctly.
Once the encoder strip has been re-seated, close the lid to the unit.
Re-connect the power supply to the All-In-One.
Press the Power button. If the encoder strip was re-seated
correctly, the Hardware Error: 502 code will not
appear.
