Televison & Video Logo
How can i reset m'y PX-720C scasio? Please help me
I have a Piano from Casio Named The PX830 BP.I also have a Sustain Pedal Model from Casio named the SP 33.Will connecting the SP 33 into the PX830 BP work?Please tell me if I have the wrong model.
Unfortunately, the SP33 pedal will not work with the PX-830BP. Casio lists that the SP33 will only work with the PX-150BK, PX-150WE, PX-160BK, PX-160GD, PX-350BK, PX-350WE, PX- 360, and PX-560 keyboards.
The PX-830 manual does not list the stand or the pedal unit as separate items if you need to replace them. The pedal unit has 3 pedals like a traditional piano. I wish that I had better news for you.
Feb 04, 2016 • Casio Music
1helpful
Apc symmetra px stuck on self test
Place UPS into internal Bypass (Static Bypass) via the display. Then place unit back to Normal from Internal Bypass(Static Bypass). See if that helps. Or shut the unit down completely by placing UPS into Static Bypass first and then place UPS into external bypass mode, switch is located on the bottom front of the UPS. Please follow the UPS Manual to help you understand the procedures. Also recommend doing this after hours, not during business hours.
1helpful
How to reset epson t 60 printer
Depends on what you mean by "reset".
If you're referring to the waste ink counters, you can either:
  1. Locate a copy of the AdjProg service utility and use that to reset the waste counters
    Note: Will not work on MacOS or Windows 8
    ... or...
  2. Download the WICReset (for windows) or iWIC (for MacOS) and purchase a WICReset key to reset the waste ink counter that way.
Whatever you do, remember that resetting doesn't deal with the waste ink inside the pads so you should be looking at changing the pads (not easy to do yourself) or fitting an external waste ink tank like a printer potty.
Please provide manual for Plextor px-eh40l. I need to reset to factory specs - wipe out current data - be able to login defaults and reset pw
You should be able to go into my computer and simply right click the drive an go to properties and then advanced and format. That should do it. If not you will have to go into system management. If you need help any further just msg me back.
Rob
If my answer has helped you today please offer four thumbs up as thanks!
How reset E-91 ( wast ink ) ( reset tool ) on epson stylus rx 520
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
1helpful
NEED HELP GETTING THE USER GUIDE FOR MY REMOTE/Model # PX-RC1?
For clarification, may I know the Brand of your remote.? There was several model to PX-RC1..
Thanks
7helpful
5answers
How do i install the drivers for a deskjet designer 720c plotter on a pc with xp pro
Dear HCUSH,
Click on the link below:
http://members.driverguide.com/driver/de...
Click on the HPVUD50.zip link, this will take you to a page where you can buy it for $2.99, download it IF you view about 8 ads (Just select no thanks, or next ad) which is what I did. Or get a premium membership.
Needless to say I have the file downloaded and if you had you email open I would send it to you. It is 2.41 meg zip file and has the 720C dll in it. So just select the button to view the ads and download it.
Once downloaded, unzip it into a directory, and add printer> local (Dont detect) > Select I have disk and browse to the directory you unzipped to. Then select the 720c and you should be good!
ADDED###########
Another way is click add printer > NEXT> Local (Dont automatically detect) Next> LPT1 (assuming it is not USB) > Select HP in the left window, then select HP DeskJet 720C in the right window. click Next> Next> Next> Next> Finish. Click OK, It should now be printing a test page.
Sure this helps
2answers
DRIVER DESKJET 720C
You can download them here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=58707&lc=en&cc=us&dlc=en&lang=en&cc=us
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
