SOURCE: I lost the instructions to my 9 ft GE Trim-a-tree
same problem but many more lights involved. buy the $20 product called "light keeper pro" and follow the instructions. this device fixes this problem by either flashing a charge through the burned out section to 'heal' a failed shunt. if that doesn't work you can trace the current with the device to find where it is interrupted. the device chirps when it senses the 60 cycle hum of the a.c. current. replace buned out lights as soon as you find them as they cause an overload in the remaining lights in that circuit.
SOURCE: NEW WIDE RANGE MOTION SENSOR EVEN AT LOW SENSIVITY
Hello ardata.... Since you already have it set to low sensitivity your next step is to turn the sensor so that it points more downward or more away from the tree. Joe
Thanks for choosing Fixya!
SOURCE: fruit tree beetle boring into tree
Check plant stores for traps. Maybe a Japanese Beetle trap will catch them.
there is a little tab behind the air filter but facing forward. it is a funny shape. hook the spring end over this tab and you should be good to go
