SOURCE: Model GSL22JFPHBS
Try to clean you condenser coils and also adjust the the fan behind the freezer panel inside...It must help you out!!...But basically did you reduce your Temperature in the Refridgerator to most possible minimum value??...Thank you...
Please Post back on how things turned or for further assistance...
Regards!!!...
SOURCE: When cold outside, door only opens a few inches
1.Check to see if the door is running correctly.
A. Run the door down and pull the emergency release. See if the door will run easily by itself.
1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
B. If the door runs fine then check the up force on your operator (the box that hangs from the ceiling and reads Craftsman). If the light(s) on your operator go from front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
SOURCE: cold weather. Opener lifts door ~8
If there is any grease in the tracks clean it all out. On the rear of your motor unit you will find the 'up force' control. Turn this about 1/4 turn and try. You also should take a good look at your door springs and make sure one isn't broken. Release the door from the opener and open it manually. Shouldn't be heavy and should stay when released about 1/2 way up.
SOURCE: remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
SOURCE: I have a leak in my Dreamaker Eclipse hot tub.
Thats the problem with Dreammaker tubs, access can be a pain and theres no easy way of getting to the pipes.
I would usually gain acces from the underside which ensures that any holes that need to be made to gain access wont be visible in the future.
Good luck locating the leak.
Kind Regards,
Ian.
http://hottub.synthasite.com
Winter
Winter Tires
Better Starting Grip in Icy Conditions.
A special Winter Flex Compound, specially formulated to maintain its grip under the most extreme cold-weather conditions, including snow and ice, to help deliver better starting grip and shorter stopping distances.
Better Traction In All Winter Conditions
Cross Z-Sipes Technology uses a specially designed curve that locks the sipes in place, helping to provide improved grip on snow and ice. And because the sipes are full-depth, their grip lasts winter after winter.
Quiet, Smooth Ride in Cold-Weather Conditions
