Question about Water Water Heaters
How do you light pilot on Richmond water heater
    New Friend:
  • 30 Answers
Remove the pilot cover on the outside of the water heater. Turn the gas valve knob to "Light". Using a long fireplace match or long stem lighter light the pilot. Turn the knob to "run" or "on". Replace the cover. If it will not light or stay lit, you may need a new thermocouple. They are not that expensive, but replacing them yourself can be a pain.
Posted on Jun 26, 2019
SOURCE:
  • 74 Answers
SOURCE: water heater not heating it's a richmond water heater
Now change the thermostats........this is the only other thing it could possibly be.
Posted on Apr 27, 2009
Gort007
  • 1187 Answers
SOURCE: Atwood water heater - pilot light and flame malfunction
Michael,
The thermocouple sensor may not be in the best position to sense that the pilot is lit.
Adjust the thermocouple mount or simply bend the thermocouple "wire" so that the pilot flame is touching the tip.
Posted on Oct 13, 2009
SOURCE: i have a richmond gas hot water heater model
resetting your lock out for richmond power vent
Posted on Nov 26, 2009
  • 746 Answers
SOURCE: pilot light on water heater goes out frequently
Check the following:
See if your heater has a pilot gas adjustment valve. It should be on the gas control valve somewhere. Not all heaters have these. It will be a screw on the valve that can be turned.
Make sure the thermocouple sensing bulb is squarely in the pilot flame and also check that the fitting where the other end of the thermocouple connects to the main gas valve is tight.
Check the pilot gas orifice (where the pilot gas comes out) for carbon build up - you may need to remove the pilot gas line and thermocouple assembly to get to this. This problem is pretty common.
Check the gas pressure to the heater. Run the hot water in the dwelling until the hot water heater starts. Check the flame on the main burner and see what color it is - it should be blue with possibly some yellow-tipped flames. If not, there could be a problem with the gas pressure at the heater or venting. If the heater has a gas pressure regulator, it may be out of adjustment or defective.
Finally, and this isn't very common, the pilot light can be extinguished if there is a draft problem, usually associated with an issue with the flue pipe venting system for the heater or another nearby gas consuming appliance.
Posted on Dec 31, 2009
Testimonial: "thank you. will try these suggestions tomorrow. really appreciate it."
  • 228 Answers
SOURCE: AFTER LIGHTING MY RICHMOND 6G40-36F1 WATER HEATER
The thermocouple is weak or the pilot needs to be cleaned. If the pilot flame is strong, try replacing the thermocouple which is the tube that the flame burns on runs back to the control valve/
Posted on Jun 20, 2010
Pilot stays lit when temp turns on the burner burns 5sec and goes out richmond water heater Richmond heater
bad flame sensor but check gas pressure first maybe need to increase pressure
Jul 28, 2017 | Water Water Heaters
Richmond direct vent water heater
The pilot lights then heats/sends a signal to open gas for burner then(burner)should stay on but if valve shuts the gas off,then have your unit checked. What ever you do,DON'T MESS WITH IT IF GAS/FLAME ON!!!!!. These systems come with a safety feature that allows gas to go on only when safe!!!!
Mar 30, 2014 | Water Heaters
Pilot light will not remain lit after butting is released
Check and be sure the pilot is hitting the thermocouple, if not adjust it. If that does not work replace thermocouple.
Mar 23, 2014 | Water Heaters
I have a richmond 5v40-36f water heater & when i light the pilot it stays on for 20-30 seconds,then when i turn it to ON it lights the burner for 3-5 seconds then goes out,i replaced the thermacouple...
Do you have a natural gas or propane water heater. You could possibly have a dirty valve which stops the flow of the gas. Has there been a change with the environment of the water heater. Check for the draft and back blow of the available air. If the water heater is over 6 years old maybe it is time to replace the unit. Good Luck
Jan 08, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water Heaters Logo
Top Water Heaters Experts
gbob59
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
