. Now that Virgin has gone can this still be used in Australia I live in NZ and will be visiting the Sunshine Coast for 12 days
SOURCE: eurovox codes
these worked for meHOW TO ENTER KEYS ON A EUROVOX RECEIVER:
PRESS MENU - THEN PRESS THE YELLOW TEXT BUTTON (BOTTOM RIGHT).
THE PROVIDER FOR YOUR AREA IS EITHER EX C&W UK (5C 01), PURE NTL UK (54 01) OR TELEWEST UK (5A 01)
THE PROVIDER ID NEEDS TO BE CHANGED:
E.G. IF YOU ARE IN EX C&W UK CHANGE THE VALUE FROM "00 00" TO "5C 01"
E.G. IF YOU ARE IN PURE NTL UK CHANGE THE VALUE FROM "00 00" TO "54 01"
E.G. IF YOU ARE IN TELEWEST UK CHANGE THE VALUE FROM "00 00" TO "5A 01"
ENTER THE KEYS FOR YOUR AREA AS SHOWN IN THE KEYMASTER SOFTWARE & PRESS THE OK BUTTON TO SAVE. THIS WILL BRING THE CHANNELS BACK TEMPORARILY WHILST A NEW SOFTWARE IS BEING RELEASED.
IF YOU ARE UNSURE WHAT AREA YOU ARE IN, JUST ENTER ALL 3 SETS OF KEYS ONE BY ONE. THIS IS A GOOD LEARNING EXPERIENCE FOR YOU ALL.
BEST WISHES - WE WILL CONTACT YOU AGAIN WHEN WE HAVE SOFTWARE UPDATES AVAILABLE
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 28/11/2008
PROVIDER CODE: 5C 01
KEY 00 = 85 AF 58 1A 36 96 B6 C9
KEY 01 = 2A E0 72 B0 9E 07 9B 5D
TELEWEST KEYS -- KEYROLL 28/11/2008
PROVIDER CODE: 5A 01
KEY 00 = 04 4D 6F 7D D5 C9 F7 9B
KEY 01 = D2 EA 29 B7 B5 52 E9 AD
PURE NTL KEYS (UK) -- KEYROLL 28/11/2008
PROVIDER CODE: 54 01
KEY 00 = 31 6F CB 3F 2E 45 5A 04
KEY 01 = EA B7 BF B2 D5 AA 46 AB
hope it helps
SOURCE: Start up screen/Shut down screen
Even thought your phone is unlocked from virgin the software is still a virgin viewity software. your can try and press on the arrows <<<<>>>>> at the bottom of the screen when the come up this will allow you to remove the network label but not on startup that requres a mobile shop to reflash the phone with generic software which will cost up to £25 shop around
SOURCE: I have an unlocked bigpond modem ,and I am trying to
once you get the setup disk from virgin and you put your sim into the Bigpond modem, gollow the Virgin prompts it should work once you have searched the right network parameters and entered the IMEI code etc. It takes about 24 hours for virgin to switch you online.
Thanks for using FIXYA
SOURCE: With Virgin. Unplugged my old modem to use New Belkin N150
Change the connection type into Dynamic
Thanks for taking the time Larry for a fellow Kiwi.
I did a bit of further research and decided to ditch the device. It's a dead duck.
Your advice confirms that.
