Question about Electrolux Washing Machines
On the Electrolux washing machine it came up with * . What does it mean
SOURCE:
  • 49 Answers
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
  • 42 Answers
SOURCE: aeg electrolux error message E20 has just flashed
it might refer to any blockage in the water supply. So cleaning the pump could primarily resolve this. but it might also be a blockage in the soap tray (when available), the tap or the hose attached to the tap or the air-gap or any water control structure. but most of the times, it is simple blockage of pump. just pull out the manual, remove, clean and replace the pump. this will solve your problem.
cheers
Posted on Jul 26, 2009
  • 160 Answers
SOURCE: e 20 error code on electrolux inspire washing
e20 usually means not draining...check for blocked filter, or obstructed/ faulty pump unit...
Posted on Dec 21, 2009
  • 1417 Answers
SOURCE: What does the error message e20 mean on a front
hello,
what this sign means or indicate is an error code indicating that there is an over flow of water in the sensor / lens reader circle.
what you are to do to fix up this problem is to unscrew then washer then clean up all form of water or any form of liquid substance around the wire connected to the panel on the screen carefully do this assignment with care and avoid disconnection on other wire connection then couple it back has it was then problem of the e20 (error)is solve.
please note this,
PUT OFF ALL FORM OF POWER SUPPLY CONNECTED TO THE WASHER BEFORE DOING THIS ASSIGNMENT.
Thank you and thanks for using fixya.
Posted on Jul 09, 2010
rickead1
  • 1998 Answers
SOURCE: I want to know what
error code e 70 the control board is not seeing the proper water supply amount in this case check the pressure switch as well as the water valve assure that you are getting hot and cold out f the water valve one from each side if the valve is ok then you would move on to checking the pressure switch how much water is fillinig on the inside of the machine when this error happens? if you have any further questions message me back Thanks again Rick
Posted on Jan 23, 2011
What is the meaning of EL error code in electrolux top load washing machine?
Please refer this link and you will get all the information :- https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load/
Apr 04, 2018 | Electrolux Washing Machines
Code e9f on my electrolux front load washing machine
E9F on Electrolux means a communication error between the main PCB and the Interface (keyboard) PCB. Probably a job for a technician.
Sep 21, 2017 | Electrolux Washing Machines
E13 error code on my electrolux washer what does it mean
You didn't specify model of your washing machine.
For Electrolux that usually means water leaks (Maximum overall water fill time exceeded (sum of all water fills between one drain phase and the next to avoid exceeding the maximum volume).
Could be:
Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve faulty; Water circuit on pressure switch is
leaking/clogged; Pressure switch faulty.
Dado
Mar 03, 2017 | Electrolux Washing Machines
How to do a electrolux washing machine ewf1495 reset
If you mean "reset program" than turn program selector to "OFF" position and than choose new one, otherwise unplug from wall socket.
Dado
Jul 26, 2015 | Electrolux Washing Machines
I have a electrolux We71 washing machine. What does mean E13?
Go to this link: And under the heading: Scroll down past the boxes and you will see your code.
Needapplianceparts com
Jul 03, 2015 | Electrolux Washing Machines
E21 error is showing on my electrolux EWF14811 washing machine. What does this mean and how do I clear it?
E21 means a problem with the water draining.
Could be defective: drain pump, pressure switch, wiring, current leak between heating element and ground and finally main board.
Also could be drain filter or drain tube (kinked or clogged) and leaks from water circuit on pressure switch.
Dado
Sep 13, 2014 | Electrolux Washing Machines
EF 2 error is showing on my electrolux EWF14811 washing machine what does this mean?
it means that your using too much soap in your washer... the service manuel recommends that you reduce the amount of soap you are using.
Aug 15, 2011 | Electrolux Washing Machines
Electrolux ewf 1435 washing machine
Feb 16, 2008 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
