Hotpoint uy46x
Most likely the main oven element has blown. A new element will cost about £20-£40, and if you're reasonably competent you can swap it in around 15 minutes. Turn the power off, undo the screws holding the element and pull it out. Carefully disconnect the push on terminals and take the element out. You probably won't even need to test the element with a multimeter, as you'll easily see if it's blown as the insulation will have blown off. nb. You may have to remove a cover before you can get at the element but should only be 4 screws max. Refitting is reversal of removal, just make sure the wires don't fall back behind the oven casing before you reconnect them!
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
SOURCE: oven not working
You need to detrmine if you are getting a supply to the oven element, if you are , then the new element is faulty, if no supply, then you are going to have to work back from source.
Please rate my solution.
Thanks.
SOURCE: Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems
and how to fix them
For all your free videos on appliance repairs remember to
mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
