SOURCE: code for directv receiver
It looks like teh H21-200 is made by Samsung. Searching the DirectTV site gave me the code 00001 which worked for me.
Jeff
SOURCE: the sharper image jumbo touch
The instructions that came with my remote were COMPLETELY incorrect. I made note in pen in my jumbo remote manual. After hours of searching the web and piecing together various blogs, I wrote these easy-to-use instructions:
You can program any jumbo remote button this way (eg. MENU, EXIT, MUTE). Just make sure you press the same button on each remote in steps 4 and 5 (eg. MENU on jumbo remote, MENU or LIST on old remote).
SOURCE: Have the magnavox PM8FS remote but can't find a code for directv.
no... there is no code for this remote to work with the directv boxes. the best thing to do is get an actual directv remote.. $15 from directv's website, and program it to everything else you want to use it with
Look for the HD logo on the front of the set--if there and a early one it is HD READY which means it needs a box with HD connected to its rear HD input.
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
OK.
