Check out the inverter board. It supplies the backlighting on screen so you see picture. If it is messed up it could be responsible for the flashing. Assuming you see a normal picture in between flashes!
Issue with Reader Carrier... Fail To Read Menu On DVD,
Due To Lens Obstruction... Try Magic DVD Cleaner., It a DVD you insert in Then it clean the lens for you... Sometime it Work Good Luck.
If you remove the handel and open thr top of the actuator you will see a set nut on the center of the shaft that you use to set where the valve stops. If this is tight then you may have a bad micro switch in the unit and you should replace the actuator. Good luck.
this might be a bad or temp sensetive tuner, why don't you try hooking up a dvd player to your video jacks and see if the problem is present while watching a dvd disc. If it doesn't then you may have to replace the small signal board(where the cable or sat feed hooks up to the tv).
