Hello to you, we are USA are you in USA>? if not say where.
routers like this only work in YOUR country, or worse only with VODAFONE systems paid in full. (ISP accounts active !!!)
the manual is on line, google finds it 1st hit if you use the unstated model number and when you find it in 5 seconds work
you see the page, says, push reset button for 8 seconds or more.
and is now reset.
if this Router is owned by your ISP , I BET
the book shows, But im reading book 12,000 miles from USA so gawd only knows.what you have.
uN admin
pw: Vodafone,
SOURCE: Re: Password change
Hi, The below steps are assuming that your router is at default settings, you are connected to your router (preferably by LAN), you can ping your router. 1. Open a browser (IE or Mozilla); 2. in the address bar type "192.168.1.1", enter; 3. on both username and password type ?admin?, OK; 4. in Quick Setup, select Step 1, Next; 5. in Password type your "New Password"; 6. in Verify Password type again your "New Password", Exit; 7. Save Settings; and 8. restart router. All other configurations should remain as-is. Hope this be of some help/idea. Post back how things turned out or should you need additional information. Good luck and kind regards.
SOURCE: Resetting WEP Password on Netgear WGT624
If you hold the reset pin in for more than ten seconds(I always count to 15) it will do a Factory reset...this will set all back to factory specs
Then you can set a new wep as well as an admin password
SOURCE: i cant log into my
Hello !
Usually on routers, on the back of the device you should have a "default login". If you do not, USUALLY, the user is either "root" or "admin" and pass "". (blank pass).
Update : I checked out your model and it says the default credentials are:
User : admin
Pass : admin
Hope that helps !
All the best.
SOURCE: How can I change my router password?
There is a button on the router somewhere that usually requires either a pin or a pencil/pen to successfully press.
Look all around it and if you press the button, possibly hold it for a few seconds, it will reset to default settings.
To connect to it, either connect wirelessly if you know the password, or use ethernet to physically gain connection.
Once you're at least "connected" to the router by either method, open a new browser window and type in
192.168.1.1
to enter the admin settings. You can there set up either a WEP/WPA/WPA2 key, or change the administrator password. These are different things, and reading the instructions on the page should help clarify which you want to change.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
