Question about Scotts Garden
What setting do I use with a Scotts Speedy Green 1000 and product that is to be spread 1 lb per 1000 sf? TIA
2 Suggested Answers
SOURCE:
SOURCE: need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Posted on Oct 24, 2010
I have a speedy green 1000 and the drop chute will not close is there a repair kit for this machine?
Phil, Check the attached links,instruction and guides contact Scotts if you have to. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Help Center Contact Lawn and Grass Experts Scotts
Scotts Speedygreen 1000 law spreader spring repair
Replacing Rusted Axle on Scotts Speedy Green Spreader
scotts speedy green 1000 parts diagram Google Search
Apr 15, 2015 | Scotts Company Scotts& Accugreeen 2000...
Need a setting for Scott's Speedy Green EdgeGuard mini
First, I went to the products website, in this case Lesco and looked up the spreader settings:
https://www.johndeerelandscapes.com/home/spreader-settings.aspx
Then, I went to Scotts website and looked up spreader settings:
http://www.scotts.com/smg/node2/SCOTTSCOM/lawn-care/lookup-spreader-settings/7800015-24900013-s
I cross referenced a product on the Scotts website that uses the same settings as one of those listed on the Lesco website and I found my settings that way.
In my case I was using Lesco Pre-M 0.86% 0-0-7 and wanted to apply 5.3 lbs/1000ft. My spreader was a Scotts Turf Builder EdgeGuard Mini with settings from 0-15. I found out by cross referencing that the Scotts Speedy Green 1000 and my spreader used the same settings. So I ended up using the recommended setting of 5.5, as listed on the Lesco website for the Scotts Speedy Green 1000, to apply 5.3 lbs/1000ft of pre emergent using my Scotts EdgeGuard Mini.
Hope this helps!
Mar 30, 2013 | Scotts Company Garden
I have a speedy green 2000 broadcast spreader and need to know what setting I need to use to spread 40 lbs per 2000 sq ft dolomite peletized lime? Thanks.
first 40lbs per 2k of lime will do nothing, rate to chemnge ph 1 point is 50lbs per 500k which would be all the way open slow walk. for your application you should be about half to 3/4 open normal walk
Feb 06, 2011 | Scotts Company Garden
I have an older rotary scotts pro turf spreader and dont know what setting to put it on for fertilizer because the settings are letters not numbers how do i know what setting to put it on?
try this:
After doing a search I found this:
From Lesco website
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's R7- X F.5
Scott's R8-A J.5
Spyker 4.5
Vicon 28
_________________________
I was married by a judge. I should have asked for a jury.
-- Groucho Marx
Oct 20, 2010 | Scotts Company Garden
I have a Scotts Speedy Green 2000 rotary spreader and want to know the proper setting for your Milky Spore 20 lb. bag (granular carrier). I have been keeping it about 50% open (Setting # 9 to 9.5) but it...
I have the same question, but have not found a direct answer. I have calculated an estimate setting of 4 or 5 for the speedygreen 2000. The Milky Spore is very simular to the fertilizer that I use. Milky spore says that 1lb covers a little over 300 square feet. My fertilizer says that at a setting of 4 it is spreading 2.6 lb per 1000 square feet (almost 3 lb per 1000 sq ft or 1 lb per 333 sq ft).
Now I may be totally off, but just bought the Milky Spore today and will apply tomorrow. I may look some more tonight to see if I can find an answer. I felt it was kind of bad that the back of the Milky Spore suggested only using a drop spreader!?
Sep 06, 2010 | St Gabriel Laboratories Milky Spore Lawn...
Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Need spreader settings for Scotts Speedy Green 3000
I found this:
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's R7- X F.5
Scott's R8-A J.5
Spyker 4.5
Vicon 28
Jul 21, 2009 | Scotts Company Garden
Garden Logo
22 people viewed this question
Top Scotts Garden Experts
Marvin
Marvin
Paul Carew
Are you a Scotts Garden Expert? Answer questions, earn points and help others
