Tried sending a fax which could not be sent. Received result saying "Line error". what to do?
SOURCE: Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
SOURCE: No answer when sending fax
The receiving fax machine never answered. Maybe their fax machine is set to MANUAL or is disconnected.
It's not your fax machine that's the problem.
SOURCE: All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
