Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
Posted on Aug 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Only hot water is being delivered. Can't get any cold water or mixture of hot and cold. Was working fine the last time used.
heavyt15
Level 2:
  • Expert 91 Answers
  • Posted on Aug 18, 2009
heavyt15
Expert
Level 2:
Answers
91
Questions
Helped
31175
Points
209
Pressure balanced...Open Hot and Cold integrals..or supplys...
  • heavyt15
    heavyt15 Aug 22, 2009
    Looks like a rebuild for this press.bal.inside...shut down the integrals...and look for an big round slotted nut remove...being careful all pressure is off...replace or rebuild...
1helpful
Is it more economical to connect both taps hot and cold or connect cold only and have the machine heat the water
JMHO, but guessing it's probably better to connect hot water to the DW. It could be taxing on the DW to heat cold water every time. At least with hot water available, the DW wouldn't have to work so hard and maybe your DW will last longer--or at least the heating element probably would. Can't imagine the cost of using pre-heated water (from a hot water heater) would be extravagant as a DW probably doesn't use that much water each time.
Why would the hot water cycle of my washing machine not work?
The solenoid that opens to admit hot water is either defective or not being energized by control panel.
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
http://waterheatertimer.org/Crossover.html
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Washer stops during cycle with FH error. Drain and all is fine. Washer thinks the water supply in not sufficient but water output is fine. Has done this a few times over the last couple of years. Last...
This is symptomatic of an intermittent malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
1helpful
Very slow, 40 minutes to make 8 cups
Run a 50:50 mixture of cold water and white vinegar through the machine several times. Allow the mixture to cool off after each run and use a filter to catch the debris that comes out of the heater/pump. Run clean water several times to remove the vinegar taste. This works great on our old Mr Coffee and lasts for some time before doing it again. Hope this helps!
15helpful
3answers
How to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
7helpful
2answers
My tim hortons coffee maker is not brewing as quickly..s there a wayto clean it
Make a 1/2 pot 50/50 mixture of cold water and white vinegar then run it through the machine in normal brewing fashion. Place a clean filter in the brewing cup to catch the white deposits that are removed. Allow the mixture to cool, then repeat the process several times while using the same filter. Finally, run several pots of fresh water through to work out the taste of the vinegar. Repeat whenever the brewing time seems to be excessive.
1helpful
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Warm water temp Maytag PAV1000aww washer
Perhaps you need to simply open the hot and cold water faucets all the way.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
On demand, tank less water heater
THE WATER IS RECIRCULATING IN THE UNIT. MAYBE CAUSED BY THE ACID. TRY INSTALLING A BACK FLOW PREVENTER
Top Moen Home Experts
john h
Gene Lawson
deton8 von Splosion
Are you a Moen Home Expert? Answer questions, earn points and help others
