Televison & Video Logo
B
B E Chandra SHekara Posted on Jun 25, 2019
We require LCD Board
As present LCD Board is Blurred we can not see use our mobile number 98454 78457 [email protected]
1 Related Answer
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jun 17, 2009
SOURCE: my maxim LCD tv power board number 05TA071B has burn how do l get
You can get the repair kit which will have the parts you need at this link, or they will rebuild your board for you.
http://www.ohmsupplies.co.uk/epages/62027733.sf/en_GB/?ObjectPath=/Shops/62027733/Products/KIT02
2answers
I need a new yahoo account
You would be better looking elsewhere. All Yahoo accounts were hacked back in 2013.
1helpful
What component should I get to fix my Samsung LCD TV?
HI,
Probably the t con broad is faulty. t con board id the on which drives the LDC panel. I some tvs its not possible to replace the T con board as it would be integrated to the LCD panel normally in 32 inches and bellow. In others i would be separate board which is replaceable individually. I have added a video to know how to locate a t con board which is replaceable individuality. As you didn't mentioned the model number its not possible to add the exact image. In all most all the tvs T con Board (individuality replaceable one ) will be placed on the top center of the tv cover with a metal shield. If its incinerated to the LCD panel then inside the LCD protection metal chassis. Check and fin which one you have.
Samsung LCD TV Repair Identifying Samsung Con Board Part Numbers How to...
www.electro-medical.blogspot.com
Picture blurred
Check and replace its backlight inverter board, or damaged backlight CCFL lamps. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
The screen of the Garmin nuvi 1390 lmt became blurred. When I tried to press the screen tightly with fingers, it displays correctly and after I remove finger it agin blurs. Please help me fix this issue.
Any distortion in the picture of the LCD display points toward a defective display. It is possible there is a bad connection between the LCD flex cable and its connector on the printed circuit board but to to check it would require taking the unit apart.
More info on LCD problems can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Have a problem with login Yahoo and getting message saying "You are logging from device we won't recognise you" and I forgot my answer for secret question.
The prompt you are receiving is called "Second sign-in verification," and it is designed to protect your account from unauthorized access.
There are several ways to confirm your identity:
Send a code to mobile phone or non-Yahoo! alternate email address:
  1. Go to the Yahoo! sign-in page (http://login.yahoo.com).
  2. Enter your Yahoo! ID and password, then click Sign In.
    • You may need to enter the security CAPTCHA code. (If you do not see a randomly generated code, simply proceed to the next step.)
  3. Select Receive Code and enter your non-Yahoo! alternate email address or mobile number.
    • Note: A code will be sent to the location you entered; make sure you do not navigate away from the page where you entered your alternate email address or mobile number.
  4. Once you receive this code, you will need to enter the code on the page where you entered your alternate email address or mobile number.
    • You may be required to update your current password.
Note: At this time Yahoo! alternate email cannot be used to confirm your identity. If your alternate email address is a Yahoo! email, please use your mobile number or security question.
Verify your security question:
  1. Go to the Yahoo! sign-in page.
  3. Provide the answer for the security question displayed and click Verify Answer.
If you do not have a non-Yahoo! alternate email address, valid mobile number, or cannot verify your security question, you may need to contact Yahoo! to confirm your identity. Note: When filling out the form, please select Yahoo! Account under "Product."
Feb 14, 2013 • Yahoo Mail
1helpful
My 2 yr old RCA flat panel HDTV 40" has horizontal lines across it and is blurred on the left side. Never had any problems before. What would cause this? Is it fixable?
Yes,this tv is fixable.The board that call the T-CON board it is dying to causing this problem.This T-CON board sit in the middle at the botton of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
4helpful
We are having SAMSUNG LA37R81B tv at home its showin blurred picture we asked repair man he said we need the tcon board number so that we can buy we now need your help
it possible that the problem is the the TCON board, you can try websites Shopjimmy.com,Ebay.com to buy a refurbish board for the replacement.
Also note that
The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
Hope this helpout..
Pictures are pink
Hi.
If pictures are pink and blurred shadow-like on all settings, both on LCD and on picture files, then you have a faulty CCD sensor.
The CCD sensor is the device that captures light to generate the digital picture.
Depending on the camera model number the CCD sensor fault is repaired at factory expenses. Call Nikon at the number listed on the owner manual, and find if the fault will be covered by recall.
If pictures are not blurred, but well defined and just kind of purple, then the green or blue channel is not working. In that case diagnosis requires testing to find out where the problem is.
Regards.
1helpful
2answers
How to kame pc to pc free calls
hi friend,
Voice Save money and talk for hours! Make free PC-to-PC calls around the world to friends on Yahoo! Messenger.
Select a friend in your contact list and click the Call button to get started. You and the friend you call both need Yahoo! Messenger, plus a microphone and speakers (or headset). If you own a laptop, you probably have these tools already built-in. If not, head over to Yahoo! Shopping to check out some headsets.
Free PC-to-PC calls are unlimited and the quality is so good that you won't believe it's free! PC-to-PC calling is currently available in the following versions of Yahoo! Messenger: Windows, Mac.
If your friend is not available, you can leave them a free Voicemail. You can also receive voice mails from friends who miss you when they try to call. Voicemail messages are delivered as attachments in email to the address you choose.
Call regular and mobile phones too Sign up for a Yahoo! Voice Phone Out account to make calls from Yahoo! Messenger to your friends' regular or mobile phones worldwide for as low as 1¢ a minute. Find out more.
Forward calls to your mobile or land line If you don't want to miss calls, even when you're signed out, use the call forwarding feature to send incoming PC-to-PC calls to another phone number like your mobile phone (Yahoo! Voice Phone Out account required). The call is still free for your caller, and you only pay the Yahoo! Voice per minute rate for the forwarded call (as low as 1¢ a minute).
Get a phone number for Yahoo! Messenger Need an extra phone number to give to friends and family? Sign up for a Yahoo! Voice Phone In account and get a local phone number that friends and family can use to contact you through Yahoo! Messenger. Even if you're away from your PC, they can leave a Voicemail for you, or you can forward your incoming calls to another number, like your mobile phone. Find out more.
* Please note: 911 and other emergency service numbers currently cannot be accessed through Yahoo! Messenger or Yahoo! Voice services. You must use a traditional land line or mobile phone to access 911 or other emergency service numbers. Internet access and compatible PC required. Intended for use by U.S. residents only. Yahoo! Voice Phone Out and Phone In services are provided by Yahoo! Communications USA Inc., must be purchased separately and require you to download Yahoo! Messenger version 7.5 or higher. See additional terms and conditions during registration. Calls to mobile phones or other wireless devices may be charged at higher rates than calls to traditional land line phones. Additional fees and taxes may apply. All rates, promotional or otherwise, are subject to change at any time without notice. Please see Yahoo!'s most current rate table at: http://voice.yahoo.com/phone_rates.php. PC-PSTN calls are billed in one-minute increments. PC-to-PC calling between Yahoo! Messenger customers is free. Check with your internet service provider regarding any fees you will be charged to access the internet.
hope this helps u
please rate me........................
thank u for using fixya
regards
sivaranjini
LG FLatron LE15A10 LCD problem
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
