Frigidaire 14 Cycle Tumble Action Washer Logo
Posted on Aug 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire front loader makes banging noises in spin cycle
When the washing machine goes into spin cycle, it sounds as if the machine is unbalanced. The inner drum bangs loudly around inside and the machine stops to try and redistribute the load. I checked the level of the machine and I looked inside at the shock absorbers. All seemed ok. I see no leaks or any broken parts. The machine is 13 years old and never had work done. Is there anything else I could look for before giving up and getting a new machine?
Anonymous
Level 2:
Scholar:
  • Expert 123 Answers
  • Posted on Aug 16, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
123
Questions
Helped
41941
Points
280
Hi there.......if this problem has just recently appeared...its quite possible that 1 of the tub suspension springs has broken resulting in the tub lying at an angle and causing this unbalance....you can check this by tilting the machine and looking at the tub susension points
regards Sir Galahad
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
My front loader washing machine is make a banging sound during spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
I have a Fridgedaire Gallery front loader, was making a loud banging noise on spin cycle, now the whole drum has dropped! help!
The symptoms that you describe sounds like the spider arms that support the drum are broken. It is a very expensive repair. Get a few estimates, before deciding whether it is worth repairing or replacing. Sorry.
Front Loader Model #FWT449G5S00 banging on spin cycle. One bottem shock snapped replaced with new shock kit (twice) still bangs. At first I thought bang ( out of balance problem) was because of the broken...
The bearings on the drum may be going bad or the counter weight may be broken off or missing or heavy unbalanced loads. Reach inside and try lifting up on the interior drum. If it moves up and down or you feel any popping I would say the bearings are going bad. They usually make a lot more noise on the spin cycle also. Similar to an airplane taking off.
Hope this helps.
4helpful
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
My washer machine sounds like a plane taking off when it goes into a spin cycle
IF ITS A FRONT LOADER ITS PROBEBLY THE REAR BEARING, DISCONECT THE POWER OPEN THE DOOR AND SPIN THE TUB, IF IT MAKES THE NOISE OR RUMBLE ITS THE REAR BEARING,
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
1helpful
2answers
Hi, our washing machine started making very loud banging and whining noise in the final spin cycle and the machine was shaking. We have taken off the back. The springs look ok. any suggestions?
Loud banging is usually an unbalanced load. whining noise is some times debris trapped in drain pump causing it to squeal like a fan belt on a car. Strings, threads and hoses tend to get wrapped under agitator and cause noise, too.
1helpful
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
