How can I Fix S211HL Driver Error in Acer? - Computers & Internet
Acer s211hl picture unstable
Can you try a different monitor? A friend's?
Or connect the monitor to another computer?
If this Maverick then you may need an updated driver.
Apr 02, 2014 | Acer S211HL Monitor
Acer s211 HL monitor, blibks like crazy and cant see video on full screen display, but works in small window format. Can not seem to download drivers from acer? Is it my drivers?
First check the resolution and refresh rate for your video graphics adapter. LCDs are apt to blink when not at 60 Hz. (Recently I had another client with that issue.) For Windows 7, right click on the desktop and choose Screen Resolution. Click on Advanced Settings and the Monitor tab. (Other versions of Windows will have this in a similar area or Control Panel > System > Display in some combination. Mac and Unix have this setting somewhere as well.) Also make sure that you are set for the native resolution or one supported by both the monitor and the graphics adapter.
Next check the temperature of the system. Improve the cooling of the system if the graphics card is overheating.
I hope this helps.
(who had the entire computer shut down when the graphics card overheated using full-screen video for on-line video. That was a major heat issue that had the CPU heat up too.)
Aug 12, 2011 | Acer S211HL Monitor
I just installed a Acer S211HL LCD monitor. All my connections are tight. I get a No Signal on screen and monitor goes off. what the proble?
If you get a no signal message then check your video card, if the monitor gets no power at all then try replacing the cable, try a different outlet, if none of those work then the monitor is defective.
Mar 04, 2011 | Acer Computers & Internet
Pioneer DVR-K17RS ATA ACER CODE=39
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Mar 28, 2009 | Acer Aspire 5610-4648 Notebook
Acer Orbitcam does not work.
Been there. You need the driver in the Acer Site. Note !! you need the Acer Orbicam WHQL Driver as well as the Acer Orbicam Utility. The Orbicam webcam is a USB device. Pls follow this steps in sequence.
1. Install ChipSet/Lan Support.
2. Install Acer Orbicam WHQL Driver
3. Install Acer Orbicam Utility.
Nov 02, 2008 | Acer Aspire 9300 Notebook
it's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
http://support.microsoft.com/kb/314060
Jul 01, 2008 | Acer Aspire 5610-4648 Notebook
Driver and setup cd - media error
vicbac, Try here for the recovery software: http://www.driverstock.com/Acer-MF350-driver-download/4-13-3327-3411/index.html And here for the binary 'bios' http://www.acer.com.hk/english/services/download/driver.php?model=MF350B I have twice recovered my Acer MF-350 (256MB), and this will work with the 128MB version. Good luck.
Oct 13, 2006 | Acer MF35 MP3 Player
Open Questions:
Computers & Internet Logo
Alun Cox
