Contributor
- Posted on Apr 29, 2023
Re: I need help i can not get my system to run
- Check the power source: Make sure your computer is properly connected to a power source and that the power outlet is working. Try plugging another device into the same outlet to test it.
- Check the cables: Ensure that all cables are properly connected to your computer. Check to see that the cables are not damaged or loose.
- Check the hardware: If your computer is making strange noises or beeping, it could indicate a hardware issue. Check to see if all hardware components, such as the RAM and hard drive, are properly seated and connected.
- Check the display: If you are not seeing anything on your screen, make sure that your monitor or display is properly connected and turned on. You may also want to test with a different monitor or display to see if that resolves the issue.
- Try booting into safe mode: If your computer is able to start but is not functioning properly, try booting into safe mode. This will start your computer with a minimal set of drivers and services, which can help you identify and resolve issues.
