Question about Maytag Washing Machines
Maytag washerMVWB765FW3 washer will not come on after power failure.
My maytag Neptune washer mah7500 panel doesn't light up, but still works
Thought it was the door switch/grounding issues/loose wire, etc. Finally found that there was a bad capacitor on the circuit board. It was a 15 cent part that, when replaced, caused all the non-start/power failure indication issues to go away. I've included a picture of the bad part - you can see the slight bulge on the top of the capacitor and a little leakage. Hope this helps. 650c7b72-0a6b-4fe3-b776-b4d9dc5589c2.jpg
Feb 01, 2013 | Maytag Neptune MAH7500WH Front Load Washer
Tip
Appliance Repair Eagle - Maytag Washer Won't Drain
Maytag Washer Won't Drain Maytag washers are notorious for drain pump failures. The most common complaint is that it won't spin, agitate, or mainly won't do anything. The pump bearing locks up and stops the washer belt from turning. Tilt washer up against the wall, remove belt, and turn each pulley by hand. If it doesn't move, then it's locked up. Remove the front panel and replace pump. Rich Western Appliance Repair
on Oct 12, 2010 | Washing Machines
My maytag 3000 washer keeps coding F-25
F25
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Nov 11, 2012 | Maytag Washing Machines
Maytag dryer has PF error code, but when use a extension cord it works fine?
Must be something wrong with the cord itself PF means power failure:
Codes and manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 21, 2012 | Maytag Neptune MDG9700A Gas Dryer
Our maytag neptune top load washer is flashing a Lr code. Is there anything we can do without calling a service?
Lr = Locked Rotor. This could be a Motor Controller failure, a Control Board Failure or a Motor failure. I would start by pulling off the front cover and see if you can rotate the Clutch Pulley CW the wash/agitate direction of the Clutch Pulley and CCW the Spin direction of the Clutch Pulley to make sure there is no binding in the drive system. Follow safety procedures in the Service manual remove power to the washer before you do this.
This could be a difficult issue to troubleshoot with out a known good Control Board and Motor Controller…..Rich
Jun 22, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Control panel won't function
This could be a Control Board failure. I would try to recycle 120VAC power to the washer. Leave it off of about 20 minutes then re-power up. If that doesn?t clear the issue then I believe your Control Board has failed. Do you have surge protection at the washer 120VAC outlet? Have you had any recent lighting storm activity? The Service Manual can be found on this site. The Control Board is under warranty for 5 yrs from date of purchase.
Aug 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
What does the code Sr mean on a maytag neptune front load washer
Technical Manual say "System Relay Failure"
Diagnostic Code 34
Jul 16, 2009 | Maytag MAH8700A Front Load Washer
My Maytag washer has no spinning mode while in rinsing cycle. I checked the voltage-it's about 118 to 130 volt consistantly. Please advise.
Our Maytag Atlantis strted having some unusual operation problems and failure to produce clean clothes about 3 - 4 yeras after purchase. The transmission was replaced, no parts costs, reasonable service call labor costs. Has worked good ever since, another 3 years or so.
Call Maytag and they will discuss with you.
Jun 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Error code PF
THIS is a "Power Failure " Clease the code (press Cancel button) and see if it starts up
Jan 23, 2008 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
