SOURCE: Need owner's manual for IBM/Lexmark wheelwriter 30 series II
I can send you acopy of a ww30 manual for 25.00
DickyO
SOURCE: IBM Wheelwriter 30 Series II
On the l. side of the keyboard there are keys labeled store, play & delete. Press & hold store then type an address 01 thru 99 release store and type whatever you want. Upon completion press store again. To play it back press play and the address, to clear delete and address.
DickyO
SOURCE: IBM WheelWriter 30 Series II Operator Manual
The delay print and justify are both on the far rt. of the keyboard pressing these keys turns the features off and on. if this dosen't do it you're keyboard is bad.
DickyO
SOURCE: IBM Wheelwriter 10 Series II 6 Beeps 1,2,3 Blinking
Check in the area where the printwheel is installed for paper or other debris. If it does the same thing with the printwheel out then it is probably a printwheel sensor.
DickyO
SOURCE: needing bold typing on IBM Wheelwriter 6 Series II
To get bold you need a WW 10, 15, 1000, 1500 or any of the later models have this faeture.
DickyO
