Likely it is flooded. Try starting without choke. Move control lever into choke position, then back to start position. This sets a high idle throttle/no choke. Don't touch throttle or it will drop throttle position from high idle to idle. Set decompress and pull starter cord no more than 3x.
You may have to remove spark plug and pull start cord several times to get the excess fuel out of the cylinder and crankcase. Dry spark plug with compressed air or starter fluid. Reinstall spark plug. Pull starter cord no more than 3x. If it doesn't fire, remove plug and inspect tip. If completely dry, no fuel. If wet either no spark or it has flooded again, check for spark.
SOURCE: top thermostat reset button kicks out
The top button is connected to the top heater element which is likely shorting out. Drain the tank below the element that the thermostat is attached to. Remove and replace the element
SOURCE: kymco people 150 when i push the starter button
The starter relay needs replaced. If you follow the + wire from the battery, it goes into a box with a + wire on the other side of it. If you jump power across the two wires, it should start
SOURCE: Stihl ms 250 chain saw won't start, doesn't seem to catch spark.
dry the plug asmall squirt of aerostart in the top of carbywith air cleaner off full throttle pull the rope and she should fire up make sure the on/off switch is in the correct position. no don`t laugh ican remember nearly completely stripping amotor years ago before ichecked it put it all back together and it started first go try the aerostart and switch
SOURCE: CHAMPION VANTAGE 35 PETROL LAWN MOWER
the recoil dawgs in the cover housing are either shot or not engaging into the top starter cone
SOURCE: wont start by kick start but will by pull start
it could be the gaskets around your carb are bad and leaking air if so its thinning your gas fumes with more air then what is needed inside your combustion chamber witch is causing your engine to stop running like that. best of luck
