Question about Alcatel Cell Phones
How to turn on alcatel without power button - Alcatel Cell Phones
Someone gave me an alcatel 5044r and i dont know the pattern on the liock screen
Factory Reset.
Power down. Press and hold On Button and Volume Up button until you see the Recovery Console.
Feb 27, 2018 | Alcatel Cell Phones
How do I turn on my alcatel onetouch phone?
Make sure it's charged up then push ether the green or red (answer or end buttons) hold until late it turns on it do think that's how it works with them or there a power button on top or side should be quite easy push and hold in till something happens
Feb 12, 2016 | Alcatel Cell Phones
My alcatel no rispond it just get off. how how do i turn it on
Make sure the battery is seated correctly in the back of the phone. Press and hold the power button until you see an android icon. If it powers off after this, or seems to not respond when the power button is pushed and held, it is likely you have either a bad battery, bad connectors, or a bad power supply unit onboard the phone's mainboard. You can also try starting the phone while attached to a charger with or without the battery. At the very least you should be able to get into recovery mode. If you can't do that then your phone maybe dead.
Jan 17, 2015 | Alcatel Cell Phones
Alcatel one touch wont turn on
The power cells may be bad will not hold a charge. If you are plugged into the house power outlet using the Power Adapter, it could be defective. Check both conditions.
Jan 10, 2014 | Alcatel Computers & Internet
My alcatel one touch 4030a power button isnt working and i dont know how else to power it on
Plug in with the 4030a's charger or the usb cable from a PC and it will power up. I'm having the same problem and this is now the only i'm able to turn it on aside from pressing and holding the power button hard for about 5 seconds or so
Dec 12, 2013 | Alcatel Cell Phones
Alcatel one touch t10 freeze
for alcatel t10 maybe you can try to press the power and volume up button simultaneously and release the button when you see the android logo and there is a red triangle above it and wait till it reboot this might work..we have the same problem but difference is it stays on the lock screen and it never allow me to unlock it if you're experiencing the same problem this reset instructions might not work.
Jan 05, 2013 | Cell Phones
Cell Phones Logo
Top Alcatel Cell Phones Experts
D. E. Hev
Tony Pez
Level 1 Expert
Mark Snell
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
