Microwave Ovens Logo
s
surya satyal Posted on Jun 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset microwave - Microwave Ovens
David Emmel
Level 2:
Sergeant:
  • Expert 295 Answers
  • Posted on Jul 01, 2019
David Emmel
Expert
Level 2:
Sergeant:
Answers
295
Questions
Helped
128410
Points
781
There is no manual reset. Unplug oven for 5 minutes then plug it in. If no results contact an authorized Technician for service.
How do I reset my Kenmore microwave model 721.80019401?
Why do you need to "reset" the microwave? The is no reset for a microwave.
1helpful
2answers
Reset lg microwave LMHM2017ST
As far as I am aware, you can reset the microwave entries with the STOP/CLEAR button. This is the only way to clear all entries on the oven.
My microwave want cook
Hello
and/or circuit breakers, particularly in the case of recent power failure, and reset if necessary.
Unplug the microwave, wait 30 seconds and plug back in to the power supply to reset the microcomputer.
Open and close the microwave door firmly and press "Stop/Reset." Select a new cook time and press "Start."
Ensure a proper cooking temperature and/or time is chosen, as low cooking temperatures or short cooking times may prevent the microwave from heating food appropriately. Press "Power Level" to ensure the microwave is cooking at 100 percent power.
Contact an authorized service technician if the problem is still unresolved.
2helpful
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
No power to viking microwave unit.tripped fuse in house and than reset fuse but doesnt work.
Check to see if you have a "reset" button on your microwave, or even just by pressing the "clear" button first. Check to see if you have a "master" or "red" reset or "test" button nearest to your microwave on a light switch and reset that if applicable. You could also check to see if your unit has a fuse and replace that. It's possible when you tripped the fuse in the house you might have blown the fuse in the microwave.
Microwave resets after start
See this FixYa solution. even if your model number is different.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
13helpful
Emerson MWG9111SL microwave reset switch
my microwave stoped woring and i dont know where the reset button is can someone help
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
