SOURCE: My computer does not recognize flip video F 260 ultra camcorder
do u have the driver cd which came with the product. else go to the web site of the company locate the driver and load it on ur computer.
SOURCE: western digital passport 160gb external ( device not recognize
As you did not specify 2.5" or 3.5" I will give you both sets of steps:
If it is a full sized hard drive and requires power, it may not be getting enough power, have the AC adapter tested at a computer shop. If it is dead/dying replace it, if not move onto the next step.
Try a new usb cable, also available at most computer shops. If the new cable works at the shop try your old cable as well. If the old one doesn't work, buy the new cable, problem solved if it does work the problem is either in the caddy or your computer.
Assuming it's in the caddy, now have the people at the shop swap the HDD from your shell into a new one and test the drive again, as with the above if it works you're done. If it doesn't the problem is internal to the actual HDD. Time to buy a new external drive and send the old one for recovery if it has any crucial data on it.
Let me know how you make out and if needed I will provide additional steps. Also if you need data recovery help let me know your region and city and I will recommend an appropriate facility.
Chris
SOURCE: Notebook does not recognize My Book / Western Digital hard drive
I have solved a similar problem to this. My laptop would not allow me to get to my WD Passport. The driver was fine and no errors were reported - it recognised the drive when I ran the hardware removal utility - I just couldn't see it from any of my windows applications and therefore couldn't get to any data.
The problem was that the passport was being designated as E:\ but my laptop already has a network drive mapped to E:\. When I am in the office the computer connects the network drive to E:/ and so my passport automatically picks the next available letter - F:\. Away from the office, the network drive is still buit shows as "disconnected network drive" and somehow the laptop gets confused into designating both the the passport and the disconnected network drive to the same letter. so the passport is not visible in My Computer.
To fix it I went to My Computer, right clicked on the disconnected network drive and select Disconnect from the options there. And hey presto the passport appeared!
You can see which letter your USB HDD is assigned in the device manager in XP. Right click on the device and go to the Volumes tab - click on Populate and the drive letter should be shown there. If that doesn't match what you see under that letter in My Computer it looks like you have a similar problem & so disconnecting whatever is there in My computer might help.
SOURCE: USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
SOURCE: Samsung YP-U3 is not recognized by computer
it is not appering in my copmuters but it is charging.
what does my nook mean? I have the top 2 models, so know nook very well
the USB cable connected to unstated PC?
you see 2 virtual drives, one main and one IS SD card. with files on all those.
see say in windows explorer. (this PC) w10.
so that say you are using some odd, adobe program app and it can not see that virtual
NOOK drives?
no app version stated, seems the problem is this.
1: wrong version of adobe.
2: or looking at protected ebooks not allowed this why....
are the nook ebooks side loaded or not?
the manual on the nook overs that.
I can put even PDF files on my SD nook and read those and more. even free ebooks,. there. vast.
some newer nooks you must in the nook enable external USB access to so that (security)
Also if using w10 are you.?
W10 running relic, apps, (are you) will not handle some types of file structures OLD.
upgrade Adobe and try.
June why use this ADOBE at all. tell me.
it is very very restrictive APP and worse.
my guess,
w10 and old version of Adobe. 2008, 12 years old versions?
It will block you for DRM, (ownership issues)
read the horror here first, DRM stuff.
https://en.wikipedia.org/wiki/Adobe_Digi...
why not just use free ebook readers.
like,,, learn to pick better APPS
Calibre
https://calibre-ebook.com/
i have no troubles at all using Calibre
on my color NOOK. zero.
for sure all side loaded. to SD card.
I can even drag ebooks to my SD and the can be seen in NOOK OK and Caliber both.
no kidding. why pay for this>>>?
you posted and never once told what files you have, we can not guess that,
like these?
see this list? free?
https://www.epubor.com/25-sites-to-downl...
the list of free books now is endless.
paid books are protected with DRM
so many apps honor DRM and block all ******* uses of paid books.
may or may not.
lean to use free readers, first.
I can even run a W10 app that looks like NOOK running on PC from the makers B&N
on my laptop, 1000s of free books.
no files told. at all, and posted.
nor the version of Adobe running.
file names not told (extensions)by you.
nor where you put them
nor if sideloading turned on in NOOK.
mine can do *.epub, *.PDF and *.txt
at least.
