Televison & Video Logo
Panel shows station P. Fault program? - Televison & Video
Can't program for analog stations
Sound like tuner fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
When menu pressed set goes int picture program. not station setup
Main system control memory IC fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2answers
How do i get channel titles to show onscreen
Press the 'Display' button on the remote control once.
Hd stations only show on part of the screen
Welcome to the world of HD programming. What you are seeing is the different aspect ratios that the movies are filmed in. In some respects there is no fix for it just something you have to live with.
1helpful
How to program 1995 900se saab radio
Tune to the first and lowest station on the band that you want and push and hold button number one (in the row of buttons immediately below the station display) until the number shows on the display and flashes. Pre-set one is now that station. Repeat, using button two for the next, and so on, until you have all the stations you want programmed.
Am reception
My 2003 S class 280 shows a fault of No Pre Safe and to check my hand book. I can find no reference to this fault and wonder if anyone can tell me:
  • what it means and;
  • how I can re-set the fault.
Cheers
PROGRAMMING
You have to get into your database programing "Feat, #, * " Says enter password, Default is 00000000. Enter into "Staion" then where it says "Show sta" enter 11,12 13 etc. "show" scrole to "CO Line Ring Assignment" Enter "Both" on each station you want to ring. Station #10 is the only default station that will ring without reprogaming the other ones to ring along with it. Hope this helps.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
