1999 Mercedes-Benz CLK Logo
Anonymous Posted on Aug 16, 2009
Where is the trnsmission cap for clk 320 model
I want to top up the transmission oil in my clk 320 model 2001
but i can not find the where to put the oil
Anonymous
Level 3:
President:
  • Master 720 Answers
  • Posted on Aug 16, 2009
Anonymous
Master
Level 3:
President:
Answers
720
Questions
0
Helped
438079
Points
2330
Mercedes have purposely not put a transmission dipstick in their cars...to STOP any unauthorised persons from tampering with transmission fluid levels.
Electronic transmissions are extremely temperamental - if incorrect type, level is too low (or too high), this will accelerate premature wear and tear, not to mention erratic shifting behaviour.
For this reason, only Mercedes service agents have the required workshop tool (ie dipstick) which they insert into a tube in the transmission, to check levels.
If you happen to obtain the correct tool for your own use....please ensure you use only Mercedes specified fluids....and NEVER overfill the transmission case.
Cheers,
Testimonial: "very very help full"
Paula Hamilton
Level 3:
  • Mercedes-Benz Master 894 Answers
  • Posted on Jan 10, 2013
Paula Hamilton
Level 3:
Answers
894
Questions
Helped
226350
Points
2652
Hi there,If you look on ebay you will find that they sell the dipstick there,please take note of the other soution and dont over fill,take you time and just fill a little bit then check,good luck.
P Hamilton.
After doing drain n fill of transmission is there any thing to do before and after putting fluid in 2004 mercede benz clk 320
Depending on kilos... Ive heard there is an oil filter on the sump.
Also remember the necessary fill volume varies with temperature.
TRANSMISSION FLUID BRAND NAME TO USE IN MERCEDE BENZ CLK 320
As long as the specification is correct the make would be your preference! Automatic transmission fluids (ATF, Specification 236.1)
2helpful
Can you assist with where the power steering resorvoir is, need to add fluid to a 2005 clk 320
On the drivers side of the engine you will see the oil filter housing and an air tube. The power steering reservoir is under the air tube.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
1helpful
Hello, where its located the soft top relay in my clk 320 2001. Not opening THANKS!!!!!!!!!! Leo
is your soft top not working it's not the faulty relay, it's control by electronic control unit, it's call soft top control unit, so first do one thing, open boot and have a look, there are one separation lid which is winding like cover, you must have close your boot separation lid buy pulling it out and hang it on hook which is locate both side back in boot, there are two hooks for hookup the separation roller lid,you pull it out and hookup it on two hooks, and close boot then operate roof if still roof not working it's need to be diagnose because there are many sensors and switches are fitted in this system if one switch or sensor not work your roof will not longer be opening and also there are any hydraulic oil leaking or lack of oil in the pump, it will not work, so in this case you must drive your car to the authorized Mercedes workshop who have the right diagnose tool knowledge for this particular car,
3helpful
How do i check the transmission fluid in my clk 320 and if it is low what type do i put in it
In order to check the fluid in the transmission you need the Mercedes Benz dip stick. It's a special tool needed for all the 722.6 transmissions. Best thing is probably to just stop by a Mercedes Independent shop where they can check it real quick. It uses a synthetic based fluid. I always go with the factory fluid.
Error message about trunk partitioner when trying to open soft top on MB clk 320
The microswitch in the trunk is probably failing. Its just a pin switch. Get a new one and install. Its meant to warn you if there is something in the way.
4helpful
2answers
What is the oil capacity for a 2004 clk320 mercedes coupe?
to replace engine oil
with oil filter 8 qts
with out oil filter 7.5 qts
8helpful
2answers
My clk 320 mercedes wont shift into gear? what is wrong?
just had the same problem today...there is a small square false door just below the D on the shift plate...the tow guy put a pen into that door and i was able to shift it out of park. now the car won't shift gears as i drive because the car is in 'safe mode'. disconnect the battery to correct. the shifting issue is still unsolved but it appears to be an electrical issue in the transmission but NOT the actual transmission. hope this helps
1helpful
Transmission leak
Hi, Joe here to help,
The ONLY oil you should use is Mercedes transmission oil. As far as how much to put back in, 4 qts if you do it right away, 4.5 qts. if you let it drain a while.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
