SOURCE: pairing my bluetoth to my blackberry curve phone
When it is turned off, hold the main button in for 4 seconds until the light flashes red, the release. It should flash red and blue. This means it is in pairing mode.
SOURCE: play station 3 dvd remote pairing instructions.
OK I FIGURED IT OUT!!! First turn off the system(ps3) make sure that you take the batteries out of the remote. Then when you turn it back on go straight to system setting, setting accessories, setting blue tooth device. AND THEN IT WILL TELL YOU TO HOLD DOWN THE START AND ENTER BUTTON DOWN!. Don't forget to put the batteries back into the remote. It took like 3 seconds.
SOURCE: pair sky+ remote to tv
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Code: 0206
4. Point your Sky remote control at your TV and press the vol + & vol - buttons. If this turns the volume up and down as you'd expect, then the tv should be set, press Select and the remote should work
SOURCE: Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
SOURCE: Pairing
press and hold the button (on/off button) on the ear piece until the light becomes blinking blue and red. Turn on the bluetooth scanner of your phone and search. Select the handsfree and pair them. Simple.
If you turn on your handsfree and the light is blinking purple, that means you need to turn off the handsfree and restart with holding on to the button on the ear piece.
