Computers & Internet Logo
Karen Larose Posted on Jun 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get rid of the tab setting - The Computers & Internet
Larry Ng
Level 3:
Top Expert:
  • The Master 14,603 Answers
  • Posted on Jun 24, 2019
Larry Ng
The Master
Level 3:
Top Expert:
Answers
14603
Questions
0
Helped
3279329
Points
66638
On what.
no what stated.
I have a iPad Pro and my screen has changed from a full screen to one that us 1/2 full what is my problem
How to Turn Off Split Screen on iPad Split View is enabled by default on the iPad. To utilize the feature, you can drag an app from your dock to the right or left edge of your screen to open the app on a portion of the screen. If you have multiple apps open and want to close one without turning off the Split Screen or Multitasking functions in settings, you can return to a full-screen view of a single app by dragging the edge of the app you want to remove to the edge of the screen.
If, however, by "getting rid of split screen on iPad" you mean turning the feature off completely, that's something you can do in Settings. To turn off split screen on the iPad:
  • Open the Settings app on your iPad.
  • Tap General.
  • Select Multitasking & Dock.
  • Toggle off Allow Multiple Apps.
How to Get Rid of Split Screen in Safari on iPad Using split screen in Safari on iPad was a new multitasking feature for iOS 10 that continues in iOS 12. This allows you to open two separate Safari web pages simultaneously on your iPad. To start, open Safari on the iPad. You can then open a second Safari tab in split screen in one of four ways:
  • Tap and hold a link; select Open in Split View.
  • Tap Command+N on an external hardware keyboard to invoke Split View.
  • Drag a tab from its space to either the left or right side of the screen to open it in split screen.
  • Tap and hold the icon that opens your tabs view in Safari. It looks like two overlapping squares. When you tap and hold, options will pop-up. Select Open Split View.
But what if you want to get rid of split screen in Safari? What if you're done using the two tabs-how do you turn split screen on the iPad off? To close split screen in Safari on your iPad, you can do one of the following things:
  • Drag the tab(s) from one of the screens to the other. Once the last tab has been dragged to the opposite side, Safari will return to full screen, which will turn off split screen.
  • Or, you can tap and hold the tabs icon, which looks like two overlapping squares. Then select Merge All Tabs. This will merge all your Safari tabs back into a single window, which gets rid of split screen.
My Lenovo yoga tab 3 10 inch has an annoying screen orientation icon how do I get rid of it.
Here's how to get rid of it!
First,
go to settings and tap on "display".
Then, tap on "advanced".
Next, tap on "display rotation".
Finally, disable the "display rotation" toggle.
That's it! The screen orientation icon should no longer appear in the notification bar.
2helpful
How get rid of advertisements on my ipad2.
Try using Firefox on the iPad. In its settings, you can have it block pop up windows. You can also try using its private tab feature.
Can't get rid of yaimo search tab
yaomi search is added to your browser by a certain rogue program. If you want to restore the former search engine and homepage, you can enter the Firefox advanced settings page and reset related browser data. Detailed removal guide at http://howtovirusremoval.com/how-to-get-rid-of-yaimo-com-redirect-virus/.
1helpful
Swagbucks won't go away
What web browser are you using?
For most just go to settings and change it.. If your using chrome then first check your extensions and delete anything you dont need and then change the settings.
When i start the computer up, it always comes up with a screen saying: "windows boot manager choose an operating system to start, or press TAB to select a tool: windows 7 tools: windows memory diagno
Noramlly this happens only if u have 2 or more operating systems on your pc and this is helpful in that case.
Anyway if u wanna get rid of this, then download and install EasyBCD and open it.
Then go to "change settings" menu and set bootloader timeout to '0'.
Your problem should be solved, Additionally, you can check "add/remove entries" menu in EasyBCD and delete any entries other than windows 7.
1helpful
2answers
I'm annoyed at seeing the emachines search page, how do i get rid of it?
open internet and then click on tools and internet options. under general tab you can type in a new homepage.
still under general tab under search click on settings and you can change your default search engine.
How do I get rid of the key's doing Spanish things ?
go to the control panel > regional and language settings > go through each tab and setting and change to either (United States) and / or English-(United States)
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
