Televison & Video Logo
Posted on Aug 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a DV490H LG DVD player that is set to region 4. need to go multi region or at least regions 4 & 1. need help with a code.
Anonymous
Level 2:
  • Expert 189 Answers
  • Posted on Aug 16, 2009
Anonymous
Expert
Level 2:
Answers
189
Questions
Helped
62960
Points
580
HELLO
I found this hack on www.videohelp.com - give it a try!
* 1. Door Tray Open
* 2. Push "000" Button
* 3. Region Code: 0
* 4. Press "Pause" Button
ALL THE BEST :-)
  • mush0k Nov 16, 2010
    what is "000" button? no such thing on my remote...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1580
Points
I have a dv490h what are the codes 4 m/r . this one is asking me for letters not numbers .
1helpful
3answers
What is the code to make LG DP522H DVD player region free (0)/ multi-region? (this replaces my question yesterday where I got the LG model wrong!)
Ok so here is how it was done.
Press the Pause button on your remote control. Using your remote control enter the code 3, 1, 4, 1, 5 and 9, Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player
Or
Press the Setup button on your remote control then, Step, Next, Up and Down, select the region of your choice or Bypass for region free, save and then Exit the menu.
LG 3200E, LG 3520, LG 4351, LG 4721P, LG 4730, LG 4821P, LG 4950S, LG 5083, LG 5822N, LG 593W
2answers
Region free code for LG BH7520
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
7helpful
4answers
I have a LG HT554PH home cinema and would like a region code to enable it to play region 1 dvds. i have just paid £5 from a website and it is no use my dvd player wasnt on the list. there is a reion...
Hi
To make the player as region free, switch on the LG HT554 Player. Push the eject button to open the tray. Now, press “0” on your player 4 times or until the region code settings shows up on your player. It will show the current region code and will then ask for new region code. Press “0” on your remote to set it as a new region code(0=All Regions). Press Enter key on remote, now restart your player and check the player by playing the DVD’s. It should be region free now.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
4helpful
4answers
I need to make my LG DVD Receiver HT503 region free
I need step by step instructions how to set up my home cinema LG ht503
Regional code
You should contact the manufacture support to see if they have a version of firmware you can install in to the player to re-program it for the UK standard.
In most cases you will have to go out and buy a player that was originaly designed for the region where you are. You can also shop around to see if it is possible to have a multi-region player. In some locations these are legal to be sold.
Jerry G.
Need the code to unlock regions on LG V9120W
1)turn on power
2)draw tray open
3)push 0 button 3 times
4)press 0 (region code)
5)press pause
OR
1. Turn Player on with no disc inside
2. Set the Unit to DVD mode (Not VHS)
3. Turn Player OFF
4. Turn Player on with no disc inside
5. Press pause on the remote control
6. Then key in 3 1 4 1 5 9
[CODE -- will then be displayed on the player display]
7. Key in desired Region number
[0 for Auto Multi Region, or manually select 1 to 6]
8. Then Press Pause again
9. Turn off player and wait 5 seconds, then back on again.
10helpful
2answers
Multi Region for LG DV398H
for 'all' LG dvd players to break coding follow these steps.
it worked for me, i was told it works for all LGs...
step 1- POWER ON "NO DISC" appears on screen;
step 2- press PAUSE, 3, 1, 4, 1, 5, 9;
step 3- "CODE_ _" appears on screen;
step 4- 0, PAUSE, then POWER OFF!!!
that's it, good luck guys! hope it works
3helpful
LG DVD PLAYER DV8621P
Turn on the unit, with remote, (no disc in player), press pause, then key 3 1 4 1 5 9
Instructions for changing region code appear on screen,
Set to Region or Disc you want to play, 1, 2, 3, 4, 5, 6, or 0 for all. Press pause again. Turn off machine.
4helpful
Regional code
open tray
Press PAUSE
enter 0000
The region code set page should appear.
Set code. 0 for multi region
Press PAUSE.
OR
Make sure your TV is on and the DVD player is active on it
Unplug the DVD player
plug it back in
wait for text "nodisc" to appear on the DVD display
Use remote control to open tray (tray must stay open)
Use remote control to Press "Pause" (you won't see anything)
On the Remote control number pad enter the number "0000" (4 zeros)
The region code setup window will appear on your TV
on the remote control number pad enter number "0" (zero)to set multi region
Use remote control to Press "Pause" again
close tray
I own an LG (LH-W750TA) DVD player that is set for DVD region 4. I am after an unlocking code to allow me to view DVDs from region 1 NTSC.
Open tray
Press PAUSE
Enter 0 0 0 0 0
Region change screen should appear.
Enter region 1 - 6 or 0 for multi-region.
Press PAUSE
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
