My washing machine recently started flooding the basement when placed on a cycle.
Through experiments, I have determined that the reason for this is because it never stops filling during the cycle and eventually fills the whole tub and leaks out of the overflow tube.
I suspected a bogus pressure switch, but when I manually blow on the tube that leads to it, it does seem to work properly (cuts off water - goes to agitation phase).
I don't want to waste money on a repair tech or unnecessary spare parts, so the problem is most likely:
A) Crud bunging up the drum, so the water can't get to the tube?
B) A leak or blockage in the tube itself?
C) It's still probably the pressure switch anyway?
D) Something else?
Any suggestions welcomed with gratitude ;-)
Since the water stops running in and goes to the agitation mode when you blow on the tube, it is more than likely the pressure switch - one thing to check though, put it in the fill cycle [with water running in] and unplug the power cord. the water should stop running in. if it doesn't, the fill valve is sticking open and should be replaced
Testimonial: "Very helpful. Confirmed what I suspected was wrong. Many thanks!"
The water does stop running when unplugged. I tried blowing through the tube the other way and had no trouble producing bubbles in the half-full drum, that suggests to me that there isn't a blockage.
I have to agree that the pressure switch is the culprit...I'll order a new one.
Many thanks!!
Many thanks!!
