SOURCE: nothing works
Remove batteries and clean contacts both inside the battery chamber and on the chamber lid/cover.( use something slightly abrasive ). If this doesnt help replace fire fuse situated on the main pc board ( underneeth rear cover ).
SOURCE: put in new batteris and nothing happens. They are
First, make sure that the "new" batteries have a full charge. If you don't have a meter to check them with, try using them to power something else. Also, if using rechargeable batteries, make sure that they are the correct type for the camera. NiCd batteries will not work well in a camera that calls for Ni-MH batteries.
If the batteries are OK, your problem may be due to corrosion on the battery connections inside the camera. Remove the batteries and wipe the camera contacts with a clean soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any specks that may have fallen into the battery compartment during cleaning, then clean and reinstall the batteries.
The above clears about 90% of power-up problems, and I hope it works for you. If not, your camera may have a more serious problem that requires repair by a camera shop or the manufacturer.
