SOURCE: I keep receiving this message while trying to
Please make sure that your anti-virus is not blocking the google talk.
To check this, please check your anti-virus firewall settings.
According to me,your anti-virus is blocking this google talk.
BEST OF LUCK
SOURCE: Good morning. We are
The "fuser" uses heat to melt the dry ink onto the paper. So, if the fuser has malfunctioned, it must be either serviced or replaced.
SOURCE: Difficulty shaving Spanish Water Dog
The biggest issue with clipping animals (except sheep which use completely different clippers) is that once you have sharpened blades, you need to go slow and keep then blades oiled and cooled. The KOOL spray by oster works great and the clippers you are using are a good reliable brand and model. When clipping my cocker/schnauzer cross, I have a 1/2 inch guard on it (have to use a 30 or 40 blade with the guards) and it takes about an hour. I stop every 10 minutes or so to let them cool down, spray and oil them.
SOURCE: why does my facebook keep
Facebook uses a number of servers in order to work.. If it's saying that, then the specific server you are using is currently damaged or offline. If you get the message after a couple of hours, then it's worth contacting facebook directly.
If
you have only just started to see this, give them up to 24 hours to fix
it themselves. If, after 24 hours, you are still getting the error,
there are a couple of things to try.
Firstly, follow this suggestions from Facebook:
http://www.facebook.com/help/?page=742 (to clear your cookies)
If
that doesn't work, you can report it directly to
Facebook:http://www.facebook.com/help/contact.php?show_form=site_maintenance
Hope
this helps.
