Won't start dl f on display
HI. this is a Door lock error. Check the following to address this issue. Normally you will need to replace the door lock assembly in this case but, it is not uncommon for it to be just a simple loose wire harness as well.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
