SOURCE: Heats but dont dry after several attempts and load sizes and more
loose blower wheel/Stopped up filter housing
If I was Karmac I could read your mind and get the model number, probably give a better answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: screen goes black after a few seconds
Problems like these happen all the time with LCD monitors. Usually one of two things. Bad Capacitors or a bad backlight. To check this, take a flashlight and point at your monitor (usually at a high angle) and see if you can still see the desktop faintly. If so then its either the back light or capacitor. Backlights shouldnt need replaced too often as they have a extremely long lifespan. Capacitors are relatively cheap and easy to replace, all is required is a soldering iron and an inexpensive trip to a Radio Shack. Though this isnt your monitor, it is a very good tutorial on how to go about replacing the capacitors.http://www.wizardanswers.com/liquidvideorepair.html If it is the backlight, here is another tutorial for that :D http://www.inventgeek.com/Projects/shorts/lcdfix.aspx
SOURCE: I'm trying to copy from 8 1/2 x 11 paper to 8 1/2
That error comes from the sensor on the right side of the carriage at the bottom. There's a light that shines down on the paper to determine size. Unplug your machine with the carriage in the middle and use a damp Q-tip to wipe up under the right hand side of the carriage. The Q-tip should come back dark blue and that error should go away.
SOURCE: mower was running hit tree root mower quit
check the key on the flywheel where it meets the crank shaft it shears when this happens very very common
SOURCE: Pull cord hard to pull since I hit tree root
see if the blade is bent the check the key under the flywheel
