2003 Volkswagen Jetta TDI Logo
Posted on Aug 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 jetta tdi died while shifting into 4th gear
I bought the car used and imediately replaced the timing belt and all associated components, rollers, bearings, tensioner, myselft, about 20k miles ago. Worked smooth as far as I could tell. I did not drive it until replacing the belt so I don't know how this car drove before. If I floor the pedal while on the highway, it will get to about 3k rpm and then just stay there. It would not increase or decrease so I would just shift up to another gear. I remember this happening in 3rd consistently. I'm not sure if that is normal.
The other day I was shifting from 3rd to 4th and the car just died. I tried to jump start while I coasted down the hill but it would not start. Once at a standstill, I turned it over. It sounded like it was struggling to turn-over. It did not sound like it wanted to start. It sounded similar to a car that is out of timing.
I see air in the fuel line under the hood.
I haven't done anything to it yet.
  • 2 more comments
  • vze1j262 Aug 17, 2009
    Negative. I did not loosen the IP pulley, just pinned it and I made sure I got it in the correct hole. Not having any previous driving experience with this, it seemed to drive fine, after I R2 the timing belt,for the past 20k miles.
    Could the filter be clogged? Any guesses about the air in the fuel line?
    Appreciate your help.
    Thanks,
    Jim
  • vze1j262 Aug 20, 2009
    I finally pulled the top timing cover off, lo-n-behold the timing belt is broken. I'm guessing the belt I purchased was inferior. I'll know when I pull everything apart and check the tensioner, bearings etc.
    Thanks for your help.
  • vze1j262 Aug 22, 2009
    I appreciate your attempt with the 1989 jetta.
    The diagram is unfortunately of the back of the relay holder. If you could get me a pic of the front that would be great.
    Thanks,
    Jim
  • Anonymous May 11, 2010
    How did you set your timing? Did you set it using Vag-Com?
David Parker
Level 2:
  • Expert 333 Answers
  • Posted on Aug 20, 2009
David Parker
Expert
Level 2:
Answers
333
Questions
0
Helped
140467
Points
895
Sorry, not a solution to this car but your other vw 1989 jetta...only way I could get hold of you.
here is your diagram
The following information covers electrical connections and plugs to the rear of the fuse/relay panel. It completes and supplements the information in the appropriate Service or Repair Manual for the fuse/relay panel section and should be used in conjunction with the wiring diagram for the vehicle or system in question. Volkswagen part numbers shown here may or may not match those on your panel, however, if you panel visually matches the diagram, it is correct for your application.
Fuse/Relay Panel - Rear Connections (Volkswagen Part Number 171 941 821 D) 2002 jetta tdi died while shifting into 4th gear - clear.gif 2002 jetta tdi died while shifting into 4th gear - 97-3228.gif src="/uploads/images/97-3228.gif" alt="97-3228.gif" class="h_mi" />
Connections and plugs on rear of fuse/relay panel:
A Blue 28 pin Instrument cluster wiring harness B Red 28 pin Instrument cluster wiring harness (position 5 open) C Yellow 22 pin Engine compartment/engine management, left side (position 10 open) D White 29 pin Engine compartment/wiper motor wiring harness, right side (position 6. 10, 14, 18, 27, 28 open) E Black 18 pin Rear wiring harness (position 17 open) G n/a 1 pin 10 individual circuits H Brown 6 pin Air conditioning/coolant fan relay wiring harness K Neutral 5 pin Seat belt warning system/coolant level wiring harness L Grey 4 pin Horn wiring harness L Black 4 pin Headlight/dimmer switch wiring harness M Black 2 pin Steering column switch wiring harness M Black 2 pin Headlight/dimmer switch wiring harness N Red 1 pin Separately fused circuits (glow plug wiring harness) P Red 7 pin 7 single point connectors for terminal 30 circuit R Green 2 pin Open/ECM power supply relay
Note: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market. Always consult appropriate wiring diagram for specific terminal assignments.
hope this has resolved your problem
Thankyou
Anonymous
Level 2:
  • Expert 74 Answers
  • Posted on Aug 16, 2009
Anonymous
Expert
Level 2:
Answers
74
Questions
0
Helped
21193
Points
203
Check the throttle position sensor
2answers
At wht mileage should i change my timing belt on my 2000 jetta tdi
You should change the timing belt & timing kit (tensioning roller, water pump, guide roller) at every 90000 km (56000 miles).
1helpful
Replacing of the cam belt / timing belt, rollers and tensioners on VW Golf iv is now due at 180 000km service. Is it a recommendation to replace the water pump simultaneous with the cam belt?
Yes. Most defiantly replace the water pump. If the pump bearing should collapse it will break the new timing belt and do a lot of damage to the valves and cylinder head.
Good Luck with it
John
2helpful
Auto gaerbox jetta 2002
chek for tiny pipe loseconection round engine carb with fss noise.
3helpful
2002 Jetta TDI, has 180,000 miles. Engine sputtered and cut off.
standing at the front of the car pull the cover off the left side of the motor and check the belt. No tools are required the check the belt. Cover pulls up and off. It's to the left end of the valve cover.
2answers
Transmission?
definitely something in the tranny
02 jetta has 4th cylinder miss!
Hi, what engine is on your Jetta ??
2helpful
Removing Factory Gear Shift Knob for 2001 Jetta
On my 2000 jetta glx, I had to replace both the shift knob and boot as one. It is built as one unit. You have to pull the boot up over the shift knob, break/bend a clip to "unlock" the shift knob then pull up. I hope the new knob you got has the boot built in and comes with a new clip.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
