Jerry Utin Posted on Jun 24, 2019
E07in Conlog meter - Office Equipment & Supplies
My Conlog meter is not showing, I can't load my token?
We are Fixya dot com and we are based in North America. We can't fix you Conlog Meter in South Africa.
there are some ideas here, but normally you have to phone your utility company.
https://www.google.com/search?q=Conlog+meter+is+not+showing
How to clear EO1 on conlog meter
Check the Display: Look at the meter's display to confirm that it's showing an EO1 error. This is usually an indication of a communication or programming issue.
Power Cycle: Turn off the power to the Conlog meter and wait for a few seconds. Then, turn the power back on. This simple step can sometimes resolve communication errors.
Check the Wiring: Ensure that the wiring connections to the meter are secure and not damaged. Loose or damaged wires can cause communication issues.
Contact Customer Support: If the EO1 error persists, it's a good idea to contact Conlog customer support or your utility company for assistance. They may have specific instructions for your meter model or may need to send a technician to resolve the issue.
Restart the Meter: Depending on the specific model, there might be a reset or restart button on the meter. Refer to the user manual or contact customer support for instructions on how to use this feature.
Update the Firmware: In some cases, updating the firmware of the Conlog meter may help resolve communication errors. Again, consult the user manual or contact customer support for guidance on how to do this.
My CONLOG prepaid meter shows EEEEEE when I try to input the token. How do I resolve this?
Token Processing Failed Error. Contact your Utility company, the owner of the meter.
Conlog Meters (old): EEEE - Invalid Token This is caused by any of the following: The meter serial number on the token does not match the physical meter number on the meter. The UIU will then remain on protocol 2 and not detect the WMD when you try to search again.)
Empire hexing comms failed - Fastly
Fastly https://jimdo-storage.global.ssl.fastly.net > file > fa...
My conlog bec23 meter box shows EEEEEEEEE and will not
Fixya https://www.fixya.com > support > t25218968-conlog...
Sep 6, 2019 - My conlog bec23 meter box shows EEEEEEEEE and will not recharge what may be the problem - Measuring Tools & Sensors question.
My conlog meter is showing the rfcon error please - Fixya
Jul 7, 2021
I try since yesterday to recharge myy bec23ed conlog prepaid
Nov 28, 2019
How do I fix this error SEr on conlog prepaid meter - Fixya
May 24, 2022
SOLVED: Conlog bec23 prepaid meter troubleshooting - Fixya
Aug 11, 2013
More results from www.fixya.com
Common Conlog Meter Errors And How To Resolve
Geeky Nigeria https://geeky.com.ng > Technology
Mar 20, 2022 - EEEEEEE. This means "Token processing failed". It is displayed when the token is accepted by the meter but cannot be processed. It may be ...
Conlog Prepaid Meter Problems /Errors And How To Resolve
simmyideas.com https://simmyideas.com > conlog-prepaid-meter-probl...
Dec 10, 2022 - EEEEEEE. This means "Token processing failed". It is displayed when the token is accepted by the meter but cannot be processed. It may be ...
Prepaid Meter Error Codes
Straton Electrical https://straton.co.za > pre-paid > about > prepaid-mete...
EEEEEEee: Data Entry Error - When a token has been entered and found to be invalid the display will indicate this by flashing the following message: EEEEEEee ...
‎Utility Systems Prepaid Water... · ‎Conlog Prepaid Electricity Meter · ‎Joy Gas Meter.. ..
There is light around the area but I don't have in my home and my prepaid isn't displaying anything to know if I'm out of token or not
Are you in South Africa and on a ConLog Prepaid meter by any chance?
We are Fixya dot com and we are based in North America!
Although we see this type of question every couple of months, I am not sure if Conlog supply just the meters, or if they supply your electricity as well? You can ask your neighbour if they have power, and if they do, you need to contact the company that supplies you electricity BY PHONE.
EDIT. Conlog only supply the meters to the Utility Companies. You need to contact your Utility Company. There is probably a sticker on the meter, I doubt it says contact Fixya.com! :>D
Think Smart. Think Conlog | Home | Conlog Solutions
Conlog
https://conlog.com
Conlog boasts the world's largest base of Smart Meters and Prepaid Solutions with over 90 Utilities using Conlog's metering solutions and thousands of vending ...
Contact Us
[email protected] · +27 (31) 268-1111 · +27 (31) 268-1500 · 10 ...
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do
Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/
Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error :
* Press the Back arrow on the keypad - this step is to refresh the UIU ( the device)
* Type # 75 # - this is to check the signal strength
If it does not go back to the normal display
*Type # 80 # - this is to refresh the meter
Then lastly you can repair the meter and the UIU by # 36 #
The above steps will work better if you are outside the house because the meters uses the radio frequency connection
The above error will occur in instances of bad weather conditions or if there is load shedding or power failure
If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again.
SOLVED: Pole meter conlog rf con meter keep on freezing ...
Jan. 10, 2017
Meter reading shows rF CON instead of units available - Fixya
Jun. 24, 2018
SOLVED: Good day my conlog ip54 elecricity meter showd ...
Oct. 6, 2018
SOLVED: Rf con error - Fixya
Jun. 20, 2020
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ...
How Do I Load The Activation Token On My Conlog Prepaid ...
Mar. 17, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
I Need Number Codes To Reset Memmcol Prepaid Meter ...
Jan. 11, 2019
More results from www.nairaland.com
How to input a token on conlog meter
https://geeky.com.ng/how-to-load-conlog-prepaid-meter-token/
CIG Meter Activation Guide ' Ikeja Electric
https://www.ikejaelectric.com > cig-meter-activation-gui...
Conlog Meter=04xxxxxxxxx. Put the meter number and press "enter" (meter will display succeed). Step 2: Confirm you have loaded your meter activation token ... People also ask How do I load my token on Conlog prepaid meter?
How do I load my electricity token on Conlog?
Why is my prepaid meter rejecting token?
How can I load my prepaid meter Online?
Feedback Web results
NHC Meter Activation Guide ' Ikeja Electric
https://www.ikejaelectric.com > nhc-meter-activation-gu...
Conlog Meter, Input 009 & press enter and the current unit on the meter will display. EDMI Meter: Single Phase: Input 10 & press enter and the current unit on the ...
https://www.nairaland.com > how-load-activation-token...
Mar. 17, 2020 - Goto http://kctmanagement.conlog.com , Enter your meter number to generate your activation codes which are usually two 20 digits. Enter the first 20 digits and ... I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
Aug. 6, 2020
Jan. 11, 2019
Prepaid Meter Codes' How To Recharge & Check Balance ...
Jul. 28, 2018
k24674
ADMIN Andrew
ADMIN Andrew
