SOURCE: I need honda bullet user's manual in English Language
i have one in english as a pdf here on my computer i can send it to you via email, whats ur email?? -Cabnode
SOURCE: I have lost the manual (user instructions) for my ...
http://www.seikowatches.com/support/ib/index.html
There are so many aplications use of the manual will be manditory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
SOURCE: need users operating manual for seiko qhr016
The time should be done on automatic by pressing WAVE.
To set manually:
Press the [SET] Button for more than 2 sec. The Year will pop up set to correct year then press SET again to set date/mth, keep holding till it get to right month n date (the month and date does not set separately). Press SET again and set TIME then press SET again for your choice of 12hr or 24hr.
SOURCE: Just brought the kenwood dpx
To adjust the clock. All you do is hold down the bass boost button untill the clock flashes, then use the volume button to adjust the time and the forward and reverse buttons to switch between minutes and hours. When your finished setting the time just press the bass boost button again to finish.
SOURCE: seiko instruction manual
http://www.seapyramid.net/rt/seiko-qhr016slh-travel-and-alarms-clock-instruction-manual/ Full manual is listed on this link for free download.
