SOURCE: closed captioning
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
SOURCE: orion tv
Hi Gerald P, just posted we experienced same problem. Few minutes later my husband has finally solved our problem. Don't know whether you can try the same. We had an old FOXTEL remote, got onto FOXTEL site and instructions how to program remote to control TV.
Dowloaded instructions with code for TV (after trying a few tries, the fifth code solved it). FOXTEL control needs to be programmed with the code suitable to TV. By pressing "ON", "AV", Red button and Select (at same time) then put code in. Turn "OFF" then "ON" see if code complies. If not try another one until you get it.
By using the FOXTEL remote on the "AV" you can change the channels on the TV and adjust volume up or down as well.
Hope this can help you in your situation. Glad we are up and running again. Bye
SOURCE: no remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
SOURCE: closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
SOURCE: How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
