If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters ofwater and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
Possible Causes/Procedure
If too much detergent was used:
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure
switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any Cycle.
Hi
Thanks for using FixYa. Error 5d means too much detergent was used. Try the following procedure---
– Run the unit through a RINSE/SPIN cycle.
– Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things---
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
