Also have a 42" Toshiba and had the same problem, then had issues moving the channel order while some channels were set to skip.
What I ended up doing was retuning the tv. Then went through the channel list (Menu -> Setup -> DTV Setting -> Channels) and changed the number of the channels I didn't want to 1000+ (using the red button, ie 1001, 1002, 1003...). This in itself does not change the channel order, but when I then move these channels to the end of the channel list and because they are numbered numerically I can be sure I don't miss any.
Next I went to the channel options (Menu -> Setup -> DTV Setting -> Channel Options) and marked all the channels I'd moved to the end of the list as channels to skip and locked. This does not remove the channels from the EPG but it does move them to the end of the list and when scrolling with the channel +/- buttons these channels will not be selected.
Ideally I would also like to delete channels such as QVC etc altogether and would love to know if anyone has a more effective solution to this issue.
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
• You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
• If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
• If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
• To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
• Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
