Heating & Cooling Logo
Posted on Aug 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My goldstar turns on and hums, but no cold air. then it blows a circuit breaker
Anonymous
Level 2:
  • Expert 69 Answers
  • Posted on Aug 15, 2009
Anonymous
Expert
Level 2:
Answers
69
Questions
0
Helped
16017
Points
214
First you should check the power for short circuit, second you have to check the fan motor if it is burnt or not,third check whether the compressor is burnt or not.These are the three reasons.If the powering is short circuited change the cables from the mccb.If the fan motor is burned out replace the fan motor or rewind the fan motor.If the compressor is burnt out replace the compressor, evacuate the refrigeration system and charge the refrigerant.
Anonymous
Level 3:
  • Master 998 Answers
Anonymous
Master
Level 3:
Answers
998
Questions
0
Helped
248338
Points
3069
Try a hard start electronic relay(it has a big capacitor to give it extra kick to start) clean both fins...oil fan motor
Have Goldstar Model R1804h ac/heater window unit when turned to heat blows only cold air what is easiest thing to check and purchase first.
If your thermostat is working on the Heat cycle (listen for "click" when turned up and down on Heat), then your heating coil assembly is probably bad. The heating coil is in series with a Fusible Link and a Bi-metal thermostat, if any of these three fails, there will be no heat from the coils.The Link and Bi-metal Thermostat are made up as part of the heater coil assembly.
The circuit on the plug keeps tripping when I turn the unit on. Goldstar wg6007
most AC`s have a start capacitor at the compressor pump, if this start capacitor is defective your compressor will not start and cause it to draw more current than is normal, when you turn the unit on listen, if you notice a humming sound like an ac hum than this might be your problem, other units use a relay to start the compressor motor and if this relay is defective your compressor is remaining in the start winding position and will also consume excess current, obtain a diagram of your unit and this will indicate the type of start device employed and go from there
Dehumidifier keeps blowing circuit
The compressor is bad...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
2answers
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
2helpful
Not blowing cold air
There is a problem and you or an Ac technician has to find it.
AC not blowing Cold Air
take ac cage off or ac out of window so insides are exposed take out side and use water hose and clean out side coils and in side coils dont bend these coils or u will be sorry,,,clean out good if not stoped up have freon put in
Our air conditioner seems to be working fine yet t won't blow cold air. Its just room temp air actually feels like you're standing in front of a small fan.
check outside unit large pipe should be cool or even very cold small pipe should be warm to touch that will eliminate some questions in order to solve problem also check circuit breaker for outdoor unit see if fan on outdooor unit is running and listen for compressor hum
Friedrich QuietMaster SS12H10
It is probably either the Compressor and or the capacitor that has failed. The compressor will hum and pull a lot of amps when it has seized up. Sounds like it is time for a new unit.
Top Heating & Cooling Experts
Paul Carew
john h
