Question about Maytag Washing Machines
Maytag 7851awso have changed the door latch . Diagnostics say door latch problems, tried resetting power, start will not light up or start
SOURCE:
SolutionGuy
  • 331 Answers
SOURCE: Maytag Neptune front loader door latch won't release
rewpa, 98% chance the door latch has stuck in the locked position. Yes, follow Maytags suggestion to access the "rip cord" for the door latch... (this is the mechanical override for it) to get the door open. After it's open, run another load of wash and see if it happens again. If it does, it is the door latch assy. that's the problem. BTW, the door lock light is activated by a switch in the door latch assy. There's a "motor" in the assy... it's made of WAX! Yes, a "wax motor". Before the computer goes into spin, it sends 120V to this motor. The electricity heats the wax and it expands. As it expands, it pushes a plunger forward. This plunger trips both the door lock AND the switch. This sends the signal to the door light AND the computer saying "I'm locked! Go ahead and Spin!" When the cycle is complete, the computer drops the voltage to the wax motor. The wax cools off and contracts. This retracts the plunger... opening the door and shutting off the light. So... if this light stays on, the plunger is still extended and can be overridden using the rip cord. If this happens again, let me know and I'll step you through disassembly and replacement of the wax motor.
Posted on Aug 19, 2007
  • 219 Answers
SOURCE: Maytag Model # MDB7600AWW door will not latch
double check door latch make sure connections are proper if right and still not working probably main board and panel
Posted on May 01, 2009
  • 10865 Answers
SOURCE: MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on May 23, 2009
  • 254 Answers
SOURCE: Maytag MDB7601AWW door will not latch
possibly need a new door latch assembly this is kind common on those maytags the latch assembly becomes defective or doesnt latch properly...W10130694 is the part number for the replacement part u would need you can see a pic of this part at repairclinic.com just enter the part number. you could purchase it there or online thorugh sears or etc... also check local they might stock at and be cheaper with no frieght shipping charges......to change this or check your assembly prob have to remove all screws from inside door usually a torx bit this will seperate panels and control will pop off.. hope this helps
Posted on Feb 06, 2010
rickead1
  • 1998 Answers
SOURCE: Maytag MDBtt60awb
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
Posted on Apr 30, 2010
How to unlock a Maytag double oven
Hi Mary,If the door locked after you started the oven!
Press Cancel/Off key to start a latch reset, wait 20-30 seconds and open door, or turn the power off at the circuit breaker or fuse box for one minute, then turn the power back on.
If the oven has a manual latch handle!
Allow the oven to cool, approximately 30-90 minutes, move the latch arm to the left to unlock the door.
If the latch arm will not move after cooling to room temperature, or is stuck in between full right and full left positions, schedule service.
Is the oven door locked due to power failure during Self-Clean? If the oven door locked due to a power failure during a self cleaning cycle!
Select the "Self Clean" option, then select "Cancel". Wait a couple of minutes then try to start the cycle again.
If you started the oven clean cycle by mistake!
Press Cancel/Off key. The oven will need to cool to approximately 200F(95C) before the oven door will open.
Was there an error message!
Follow directions in the display, and refer to the Error Code Symptom, or:
Reset power to the oven!
  • Power the oven down by turning off the circuit breaker(s) or fuse(s) or if you can, unplug the oven for one (1) minute.
  • Turn the power back on turning on the circuit breaker(s) or fuse(s) or plugging it back in.
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify the ovens operation.
Kind regards
David
Dec 04, 2017 | Maytag Kitchen Ranges
My Maytag front load washer , powers up and lets me change the settings, but when I press the start button , it beeps and displays d5 and wont start??
this fault code ind a door lock problem ,hence this is why it wont start , it thinks the door is not closed , id say the door latch mech. needs service
Feb 26, 2016 | Maytag Neptune MAH9700 Front Load Washer
Why won't my Whirlpool Senseon Dryer start? The control panel will not respond. No buttoms will light up or beep. The dryer has power and the door latch works properly and the light comes on inside
Always disconnect power before attempting any service. Most electric dryers require 240 volts to operate properly.
You may have only 120 volts to supply the dryer which will give you your symptoms. Click dryer circuit breaker off then back on to reset 240 volt system.Still no heat/run
This link will aid you in tear down / diagnostics/parts
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 21, 2017 | Whirlpool Dryers
Normal wash lite flashing
Hi, try pushing Normal Wash - Heated Dry - Normal Wash - Heated Dry. This should enter the diagnostics cycle and reset any faults. If it will not reset or enter the diagnostics cycle then the door latch assembly must not be engaging when you close it. You will need to check the door latch to make sure that the switches are engaging. If they are not, you will need to replace the door latch switch assembly.
Jun 27, 2011 | Kenmore Dishwashers
Washer will not start. Accidentally pressed 'off" button and now the start light is blinking and I can't change the settings or start the washer
try unplugging the washer for 5 mins. to reset the main control board, if that doesn't help check to see if both door latches are locking
Jun 03, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer Neptune flashes ul code
Well most probably its FL error code it means failure to lock. Try unplugging the unit for 60 seconds to reset the control board and then plug it back in and see if it will reset. If not, then you will need to replace the door latch assembly. Try pressing STOP/CANCEL to clear the display. If further you have the same problem then you need to change the door latch assembly.
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Maytag Washing Machines
MAytag dryer will not run. Has Power but will not start. No sensing light.
Was your dryer taking a long time to dry clothes? If so you should first check your vent and then suspect your dryer thermal cutoff.
Or,
this problem could be your door latch switch. Is your door more difficult to open, OR, sometimes pops open / or opens really easy? Then your door latch switch could be bad.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Power not coming on
When a dishwasher appears to be dead, many times the door latch is to blame. On some models, that latch has a safety interlock switch directly controls the power, so that when the door is opened during a wash cycle, power is removed.
The problem is that the interlock switch can fail or get un-aligned, so the dishwasher does not get power.
Depending on your skill level, you can investigate the problem, using a phillips screw driver to open up the latch so you can see the interlock.
Good Luck!
Apr 27, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Neptune MAH5500BWW will not spin out. Unplugged to reset and all lights will blink and set to pause. When you press start, it eventually clicks like it is locking to start, machine turns off and...
it sounds like a door latch problem. the door latch has a small "wax" motor in it that causes a lot of problems. unless you have a bunch of time to spend learning about how it works i would suggest calling a professional.
Jun 29, 2008 | Maytag Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
