Electrical Supplies Logo
Phil Renner Posted on Jun 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blackmax8450 generator pm0496750 won't start help me
sherlywang
Level 3:
Master:
  • Electrical S... Master 428 Answers
  • Posted on Oct 11, 2019
sherlywang
Level 3:
Master:
Answers
428
Questions
0
Helped
198495
Points
1063
What kind of your generator? Diesel or gasoline?
If diesel geneartor, the reason maybe as follows:
1. Fuel system malfunction, the diesel engine is driven by the starting motor and does ont ignite.
2. Electrical start system failure.
3.Injection advance angle premature or too late.
If you still need support, please visit at www.dieselgeneratortech.com to search more answer
I have a blackmax8450 pm0496750 used one time then sat 8yrs.w gas in it.unit will not start
give tune up and flush fuel system and possible may have to rebuild or replace the carb
I have a PM0496750 it runs well but does not produce electricity
If it has sat, it may have lost it's rotor residual magnetism.
Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged.
If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Hi i have a Black max, Powermate Generator model #PM0496750 ,6750 watt it run great for 3 hrs and then stop generating,,, clean the frets on rotor where brushes runs on and its good for another 3 hrs then...
You have excessive arching on the rotor slip rings by the sound of it, if you clean them and it works well then 3 hours later same problem? What is the conditon of the brushes? Also I trust youa r enot cleaning polishing them with sanpaper etc, they have a very fine finish and should be polished with a super fine grit paper or stone, pref while turning the engine. Any scratches won't work
1helpful
Hi i have a Powermate model PM0496750, 6750 Black max Generator it will run for 3 hrs then stop generating ,,if i clean the frets on the rotor where the brushes runs on it will go for another 3 hrs ,,, I...
I doubt its anything to do with brushes unless power system has shutdown incorporated, could ignition coil breaking down when it gets really hot or similar check the oil level cut out switch
Low oil sensor
I would let it cool completely and see if it starts again. There are no specific timers that say after detecting a low oil shutdown don't start for X amount of time. It is more than likely a choke setting as it is hot, and you may now have flooded it.
Husky generator won't start
did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Honda em5000sx generator won't start
I have a EM5000SX. My problem is my generator will not start unless I turn the fuel selector to off. Then crank it until it does start, turn the fuel back on. Run's normal . I run this generator for my cabin every weekend.
3answers
Briggs engine/ genreator
change spark plug and add small amount of starting fluid to breather pull with all settings in proper place if it is going to start it will or you have other problems
Top Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
