Jensen MP5720 CD Player Logo
Posted on Dec 05, 2017
Car Stereo Freeway 7 inch flipscreen-can't adjust volume, etc.
Volume is stuck on max. However, when i turn the volume to 0, it the speakers turn off but the subwoofer still plays. I cannot fade my speakers, or adjust the bass, treble, or anything. The radio and cd player also seem to be acting faulty, such as the radio playing on cd/dvd mode, or just plain static on radio mode.
5 Related Answers
Anonymous
  • Posted on Dec 19, 2007
SOURCE: Stereo volume doesn't effect Aux input volume
in a car stereo system, when you select line input, it usually assumes the device you are connecting has its own volume control. if you really want to use your cars volume knob, an FM transmitter might do the trick.
Anonymous
  • 319 Answers
  • Posted on Jan 05, 2008
SOURCE: Cannot Set the Treble & Bass
Bass and Treble controls allow you to adjust each setting from
-7 to +7 once you have calibrated your vehicle's interior sound with the optional Alpine IMPRINT software.
Is this what might be causing your setup not to work?
Anonymous
  • 52 Answers
  • Posted on Feb 11, 2008
SOURCE: car stereo
if u got an amplifier, make sure u replace the fuse with a higher amp fuse, If the face for the detatchable deck got some kinda liquid, use compressed air to clean it a little bit, make sure alternator is charging and if ur car is not running then make it run to keep the battery chargin, :)
Anonymous
  • 5 Answers
  • Posted on Feb 01, 2009
SOURCE: jensen cd 2610 aux input has little volume
first of all the rca jacks in the back of your radio are for plugging in an amp, not your mp3 player. there should be an auxiliary jack(looks like a headphones jack) in the front of the head unit. if there is no auxiliary jack in the front then you will have to go buy a new head unit with an auxiliary jack.
Anonymous
  • 54 Answers
  • Posted on Sep 25, 2009
SOURCE: Jensen KDC 9520 Car CD player lost speaker conection
sound chip inside is fried
Turning my Phonic PowerPod7 into a home stereo
To turn your Phonic PowerPod 7 into a home stereo system, you will need to make some additions and connections to the existing setup. Here are the steps you can follow:
  1. Connect speakers: You will need to connect a pair of passive speakers to your PowerPod 7. You can do this by connecting the speaker cables from the speakers to the "Speaker Outputs" on the back of the PowerPod 7.
  2. Add a source: The PowerPod 7 has two channels, so you can connect a stereo source such as a CD player, turntable, or music streamer. Connect the left and right audio outputs of the source to the corresponding inputs on the PowerPod 7.
  3. Connect to power: Make sure to plug the PowerPod 7 into a wall outlet to power it on.
  4. Adjust the volume: Use the volume knob on the PowerPod 7 to adjust the overall volume of the system.
  5. Tune the sound: If desired, you can adjust the tone controls on the PowerPod 7 to tailor the sound to your preferences.
With these steps, you should have a functional home stereo system using your Phonic PowerPod 7.
How come i can only adjust the volume levels on the center, surround sound left and right, and the sub, down but not up? is 0 max volume?
Some equipment use 0dB as the reference, and you can choose to decrease the volume from that point. If you need to "increase" beyond 0dB, you need to reduce volume on the main speakers so the volume is finally balanced between all speakers.
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Start up volume way too loud! The answer here is to push in volume button to set..my volume button when pushed in sets mute and on/ off
Annoying issue but honestly, I have no idea how to operate your "Jensen VX7020 6 2 Inch MultiMedia Bluetooth" but logic says you should read instructions. Read these instructions
http://www.jensenmobile.com/docs/common/VX7020/VX7020_IM.pdf
Watch these videoos, maybe get some hint
Jensen VX7020 6 2 Inch TFT Car Stereo 2 0 DIN MultiMedia Receiver with...
Jensen VX7020 6 2 Inch TFT Car Stereo 2 0 DIN MultiMedia Receiver Review
also some info at this website. Check it:
vx7020 manual
2answers
Why could my volume knob be stuck on max volume and not adjusting?
There is probably grease or dirt on the contacts inside the unit. Here's a video that shows you how to fix it:
http://www.youtube.com/watch?v=y4XF9PoidJQ
Hope this helps!
My stereo turns on, but no volume? It seems that it disabled all the speakers?
This is very important: does the vehicle have the Bose speakers and amplifier? If so, did you use a vehicle specific wiring harness during the installation of the aftermarket radio?
It sounds like the factory amplifier is not powering up. The amp turn on is green/white.
2answers
When the truck is turned on the speakers make a boom sound then they buzz??
is this afetermarket stereo if so check you ground on the amps
What frequency do i need to have my speakers on??
Different speakers perform better under different frequencies.
The sound you receive also depends on the box you use, and the type of car its in. In my opinion the best sound is what "I like" not what others set.
There is two ways of finding your optimum settings.
But my favorite way is to do the following.
1) Set every frequency on radio, preamp, cross over to amp and 0.
2) Turn the volume to about 50% - 75% using a song with different types of base.
3)Adjust your base gain, sonic, boost, punch or what ever settings until it sounds it's deepest. Don't over do the gain or base boost.
4)Adjust the other setting to fine tune clear sound.
5)Add the highs to see if they match up.
6)Now fine tune the amps but remember you should only need to bring the gain up or down because you had already found your deepest base. This should be the last amp adjustment unless u realize u want it lower or higher.
7)Adjusting the equalizer or EQ on the sterio will depend on the song your playing.
Note: It's best to max out at about 80%-90% sterio volume.
"I max out at 60%, but that's because I don't like twisting and twisting to get my sound up or down." One twist and im setting off car alarms.
Rear Speakers
Hello kaykayscott1,
Here's a link to the manual.
First make sure that the green green/black and purple purple/black pairs of wires are properly connected to operate the rear speakers.
You can check and adjust the "fader" and "rear volume" settings from the front panel. Go into settings by pressing the CONTROL knob. Then press CONTROL repeatedly until you get to the setting you want to check or adjust. When the display reads "R-VOLUME", turn the CONTROL knob from 0-35. Press CONTROL repeatedly again until the display reads "FADER" and turn the CONTROL knob from Rear 15 - Front 15 until you get the setting you want. Exit audio control by pressing any button.
Hope this helps.
48helpful
11answers
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
