Someone got a really bad static shock off the fax machine yesterday. Now the keypad isn't working. There is a dial tone on the handset, and we can receive faxes, but no buttons are working.
Most garage openers have a reprogram button on the lift motor. You push the button on the motor and enter in the new code on the keypad but you only have a really short time to set it so get someone to push the button from a safety ladder and you can set the code. You hit program and then push your code numbers.
Something is causing a short on the keypad bus. It could be wiring, or the panel could have had a power surge. There is also a jumper on the main alarm panel board that could be shorted. Open the panel, and make sure there is no connection between the pins in the middle of the board marked RESET. If that isn't the issue, pop the keypad off the wall and make sure that there isn't a connection between the yellow and green wires. The wires are on a harness connected to the back of the keypad, so follow them back far enough to see where they connect to the wire going to the panel.
Hi, you have a keypad problem here. First try pressing the cancel/off button for 5 seconds. If the code is still there, disconnect the power for about a minute and connect. If the error returns you will have to get someone to disconnect the keypad ribbon cable from the main board, clean the end with an eraser and re-connect it. Re-apply the power and see if the error returns. If the error returns, probably a bad keypad. E0-F2= stuck or shorted keypad....
CHECK TO SEE IF THE LED ON THE WALL BUTTON IS BLINKING - IF IT IS SOMEONE HAS PUSHED THE VACATION LOCK BUTTON.
PRESS THE LOCK BUTTON TO MAKE THE LED STAY CONSTANT AND IT IS FIXED.
HOPE THIS HELPS
the button might be a little sticky if you get a little bit of glass cleaner spray it by the button and let it sit for a minute the keep pressing teh button lightly a few times it should clear out any gunk on teh button failing that if you know how to take the cover off you can clean it that way .. if it still sticks try swapping it for a button you dont use you will ahve to take the button off by desoldering it and swapping
Press the MENU button and press 7, then 2 on the numbers keypad. You can then use the keypad to change the fax header. Press the keypad numbers corresponding to the letters you need. It will cycle through lower case first, then upper case. Press the RIGHT arrow button to advance one space between letters.
Press MENU button, then 5 on the numbers keypad. you should be able to scroll through a list using the up and down buttons. #1 is the HELP LIST, #2 is AUTO DIAL, #3 is FAX ACTIVITY which shows LAST INCOMING AND OUTGOING faxes,#4 TRANSMISSION,prints a TRANSMISSION VERIFICATION REPORT of the last transmission. #5 USER SETTINGS lists your setting. To select your report, select the REPORT NUMBER, press SET, then START, to print
Most office machines are properly grounded and don't suffer from static problems as severe as this. The machine is not repairable. Before you replace the machine, make sure that your electrical outlets are properly grounded. Then buy a line conditioner that will protect against this.
