SOURCE: unable to print
press menu then start mono then 4x arrow-up. machine will be in maintanance mode. what error code does the machine display?
to leave the maintanace mode simply unplug machine from power and reconnect again.
SOURCE: Lexmark X 83 will photocopy but not print
Ok thanks for the info:
Do you still have the the Installation disk for your printer?
SOURCE: Canon D880 Printer/Fax
1. Take off 3 plastic covers one above exit area-slide top to left to access screw
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
plastic heater membrane. remove paper jam and reassemble.
SOURCE: Paper Jam error will not reset after removing jammed paper
In many cases, you must use compressed air in a can, and blow out the insides of the printer. These printers use photoelectronic eye technology to tell you when there is no paper left, or other supplies are used up. But unless you clear that out by blowing air through and past those sensors, they do not reset. The paper dust continues to block the sensor which makes it report that there is no paper, that there is a paper jam, etc.
Try clearing it out that way.
-a.
SOURCE: Jammed document
JC
I had the same problem- jam error with no paper in it. I tried all of the suggestions to no avail. So as a last resort before I went and purchased another one I unplugged it, picked it up, turned it upside down and whacked it a few times. To my surprise when I plugged it back up it worked just fine! Haven"t had any problem since. I don"t reccomend this but as a last resort, what the heck!
