SOURCE: Homelite Blower HB180V carb adjustments.
Hi
high speed H=2 turns ,lowspeed L=2 1/2 turns
they are inscripted near the adjusting screws.
regards savumihai71
SOURCE: My Homelite 26b will run at full choke but will
make sure your fuel mixture is correct also check t your air cleaner it will not run right without it or if it extremly dirty
SOURCE: carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
SOURCE: My Homelite trimlite trimmer will only run in the
Dirty carb or adjustment needle. Or adjustment no good on carb.
Could be a dirty fuel filter or cracked fuel line. The filter is usually inside the tank. You should be able to take the cap off and turn the unit upside down and shake it so that the filter drops from the tank. If not then grab it with a pair of needle nose pliers. If changing the filter or replacing the lines doesn't work, the carburetor might need to be cleaned.
