Question about Patton PUH9000-U Heater
The Caution Light ?
I have a Patton Heater And It has A Caution Light on it. It would run for 2 minutes then the caution light would come on then it turn off!
  • 2 more comments
  • helpmelarry Dec 08, 2007
    Thanks for your help. The heater has died the other day on Thursday night on the 6th of December! I took it to some one that fixes them for the liveing and he told me that it was dieing slowly. It was best just to let it died anyhow! Thanks agian.
  • Anonymous Mar 05, 2009
    My PU9000 is new, less than 6 months old and has the same problem. Trying to find schematics and parts lists, but striking out. Patton is a part of Jarden Corp and you can find its user manual on a web site there, but not much else.
    Steve
  • Clark with Big Toast Dec 11, 2012
    Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That gets dust in it and causes it to trip. Try cleaning it. While you are there, squirt the motor bushings good and dab a drop of synthetic motor oil (just a drop) on EACH motor bushing. Personally, I required this and bypassed all of the safety features. You can bypass that sensor with soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together and put *** back in the holder and fighting the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation.
    Sorry, I meant you can do this WITHOUT soldering or cutting wires.
    New Friend:
  • 4 Answers
MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
Posted on Dec 11, 2012
  • Tiger-Heli
    Tiger-Heli Sep 15, 2014
    The reply above allowed me to get a MH-771 Heater working again.
  • Tiger-Heli
    The MH-771 was slightly different than described, though. The thermal shutdown switch that turns on the Caution light was at the TOP of the heater element box and was riveted on with wires connected with quick disconnects. To bypass it without cutting or soldering wires, I simply got a pack of Radio Shack 64-3064http://www.radioshack.com/product/index.... adapters, bent one flat, connected the wires together and wrapped with electrical tape. Works like a charm, but as advised, be careful with the modified heater.
I have one and the thermostat is defective (out of calibration) causing the problem
Posted on Jan 04, 2008
  • 625 Answers
To be absolutely certain what is turning on the caution light I'd have to see a circuit diagram on the heater. what it may be is that the air path is obstructed by something, the element is reaching too high a temperature and shutting off, if it has a fan, the bearings might be dry - hey! don't ever use wd-40 for lubing motors. use a light machine oil. the bearings in most of these heaters are oil-lite - sintered bronze. the material is porous enough to pass oil to the bearing surfaces and is free floating in their mounts.
Posted on Dec 07, 2007
SOURCE:
I need the lighted switch on front of Patton milkhouse space heater model puh680-u but can't track down web sight to order.
May 22, 2010 | Patton PUH680-U Utility Heater
Spidem Divina - one cup and 2 cup lights flash together
Hi
Caution light usually means something is out of place. Nothing will work until everything is in place and locked.
Steady water light means it needs to be primed, (run water by opening the steam knob). It won't heat until the boilers are primed.
Jun 19, 2009 | Saeco Spidem Divina Deluxe Fully Automatic...
Caution light comes on,rarely used heater. any thoughts?
Try calling 1-866-876-4332 ext 224 for tech help, it worked for me.  I only needed a temp
setting/off switch to fix mine.
Oct 21, 2008 | Pelonis WM-HO202C Oil Filled Radiator...
Yellow caution light
I also have the model 5620. with the yellow caution light on. After taking the unit completely apart I found 2 thermal fuses on the bottom of the unit(appox. size of a nickel). They are located under 'U" shaped brackets which are below the medal heating element. The thermal fuses do not reset. you could test them with a drip or two of souder or wire on the top - if you ran the heater this way it would be a safety problem as the fuse would be overridden. I am throwning mine away.
Mar 16, 2008 | Heating & Cooling
Red caution light
The red light is in conjunction with a safety. This is there in case something goes wrong, the heater doesn't overheat and possibly catch fire. If its not getting too hot, and its sounds like its not. The safety needs to be replaced. It will be a little disc shaped thing with 2 wires connected to it. If this heater also has a tip over safety, there also may be some type of mercury switch too. If you are so inclined, when you find the safety disc it should have some numbers on it. This indicates the temperature it is made to turn off at. After removing it, connect the 2 wires together and turn the unit on with a thermometer in the spot where the disc was. If the temp. doesn't go higher than the #'s on the disc after 45 seconds like you said, then you know positively that is the problem. If it gets hotter very fast, then the elements need to be looked at for defects. If there are no numbers on the disc or you cant find a replacement, then it may just be easier to buy a new heater.
Mar 03, 2008 | Patton MH761 Utility Heater
Lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Feb 12, 2008 | Heating & Cooling
Patton space Heater Model # prh-5
check that the rocker switch inside isn't stuck, when the rocker swings it shuts the unit off. if it is full of dust it may be stuck. may just be bad.
Nov 12, 2007 | Patton PUH680-U Utility Heater
CAUTION LIGHT only -- no Fan or Heat
According to the manual, the "Caution Light" means that the unit has overheated. They suggest running on a lesser setting, but you also may want to see if you can return the unit (if it is still under warranty).
Mar 31, 2007 | Black & Decker BDCH100 Ceramic Compact...
Lasko 5610 red caution light, no power
the caution light is telling you something is wrong. most wired baseboard heaters have a hi limit cutout that may be bad.  it is connected into the heater circuit as a safety device.  you could jump out this element to test this theory.  if the element is shorted, certainly it would blow a fuse or circuit breaker.  if the element is open it won't heat at all.  you need to take it apart and use a test meter to troubleshoot it.
Jan 02, 2007 | Lasko 5610 Baseboard Heater
Heating & Cooling Logo
1,084 people viewed this question
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ray gallant
ray gallant
jeff5may32
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
