Electrical Supplies Logo
Posted on Aug 14, 2009
I have installed a set of Vizia vz106-1l dimmer remote pair of switches can only get 1 switch to turn lights on and off. the other 3 way switch will not turn the light on or off. It is wired correctly what is the problem
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Aug 15, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
12244
Points
44
Not familier with this model but yes sounds like its wired incorrectly, usually on a 2 way switch you will only have 1 live comming in, it will feed common in, the bottom 2 will connect too the bottom 2 on the other switch in opposite order then the common on the other switch will fed the light.
2answers
Leviton switches getting hot
Sounds as if there is to many watts going trough switch . Make sure it is rated for the lighting load.
Vizia VPT 24 - LCD not working, switch not working after power outage
faulty switch ? faulty breaker ? loose connection ?
get an electrician to test the circuit.
I have a dimmer switch installed and it wont work with the celing fan
Your question has two switches and 1 dimmer.
The fan switch works.
The light switch works.
The dimmer does not. What is the dimmer connected to?
Dimmers typically will not control fan speed unless they are rated to do that.
Do you have a 3-way switching where two switches control same light, and you installed the dimmer in place of 3-way switch?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
DOES THIS DIMMER WORK WITH LED LIGHT BULB
It's not quite that simple..
According to the manual for your switch, it is stated "Use with magnetic low-voltage transformers, incandescent, or 120V halogen fixtures only." Also, there is a minimum load of 40W or 40VA. Your LED lamp load will need to satisfy BOTH of these requirements. Electronic circuits are not to be "dimmed" with this dimmer - but use of either the VZE04-1L (400W max) or VZE06-1L (600W max) is supported.
You will need to provide the manufacturer and model number of the LED lamp(s) to be dimmed by this switch. Or, you can use traditional dimmers (if desired) with LED lamps that are specifically labeled as "dimmable" on their packaging.
Once the lamp model is known it will be possible to learn about their dimability assuming that they are not cheap imports with no real customer support contacts. Name brand lamps will have this support, and you can even call them yourself and inquire directly about the suitability to task for the dimmer. If the lam company doesn't know about the switch, contact Leviton with the lamp info at Customer Service: 1-800-323-8920 • FAX: 1-800-832-9538 Tech Line: 1-800-824-3005
1helpful
2answers
I just installed a Leviton IP106 Illumatech dimmer switch. It was replacing my existing rotary dimmer switch. The switch is a 3-way wiring job, with another 3-way toggle switch (no dimmer) on the other...
The Leviton IP106 Illumatech dimmer switch must be installed at the switch location where the hot feed exists. From your description your hot feed is at the regular 3-way switch location. Swap locations.
Regular 3 way switch does not seem compatible with the Dimmer
you have the circuit mis-wired, the wire on the identified terminal( black screw or black wire on dimmer switch) is incorrect. Turn off power and swap one wire at a time to find the correct combination. The mistake could be at either switch so if the first does not help try the other.
How do I pair this with my remote?
The programing of these remotes is slightly complicated go here and there is a step by step set up wizard.
http://www.monstercable.com/productdisplay.asp?pin=5200
I need to program a VRi06-1LX rf switch with a harmony remote
The VRi06-LX switch is in the Harmony database.  Log on to your account, select the Device tab and click on the Add Device button.  Select Home Automation/Light Controller from the drop down menu.  Then select Leviton and type in VRi06-LX for the model.  The next screen will show two models, select the VRi06-LX.  Go through the rest of the process to save the data and revise your programs if necessary.  The changes will not take effect until you update your remote.
3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
