I've bought one thinking that it could be connected to power separately. Is there a way of using the three pin wires to attach to a normal power source? I have a 70's tuner/amp that I hope to plug the cassette player into once I get to power up the Technics cassette player. Thanks/David
SOURCE: connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
SOURCE: Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
SOURCE: Technics ST-X302L tuner - Unit not powering on
who is original remote control per technics su-x303
SOURCE: I have a 1986 vintage Technics component system
Since you have all the model info on hand, go to the manufacturers web site, look for the support page. if it is an older system, you'll want to look under older products, legacy or OLDER equipment. If that does not work, then try google. If all else fails, just remember>>> the Equalizer is the last component that plugs into the AMP's INPUT.
SOURCE: I have a Technics RS CH770 twin cassette deck
I have some to sell if you still needs?
[email protected]
